Wheel spacers or weights for slopes?
/ Wheel spacers or weights for slopes? #121
Just saw this thread. I am very interested in the subject. We also have a L3800HST 4WD, but we have R4 tires, and the R4 wheels on a L3800 can't be adjusted for width. We previously had a M5700. When we first got the L3800, it was very unstable compared to its predecessor. Our rear tires are loaded but our front tires are not. We put 4" spacers on each rear wheel, and it made a lot of difference. Our dealer said that he had never seen or heard of anyone having problems as a result of adding rear wheel spacers. My only thought on wheel spacers for a L3800 is that more width would have been better but for us would have caused issues with getting the tractor placed properly on our trailer (the wheels would have been wider than the inside width of the trailer fenders--and yes, I know that I could have backed the tractor on the trailer, but I couldn't always do that with the assortment of attachments we might have on the tractor).
Even after almost two years I am still getting used to the L3800, so I don't have a definitive answer for the OP or anyone else about the degree of slope that I think I can mow safely. I mow with the FEL on but very low to the ground. I do know that I mow some slopes that are 15% or more without a lot of discomfort, but I mow slowly and am very careful about watching for rocks and such on the high side and holes or depressions on the low side. We have some slopes we mow that look similar to those in the pics posted by the OP. If I am judging the slope in those pics correctly, I mow equivalent slopes with a zero-turn 66" mower, which has a much, much lower center of gravity than the L3800. We have a pond that we mow around. I mow the bottom of the steep slopes on the pond dam and steep sides around the pond with a bush hog by backing the tractor down the slope to the water. It is pretty tedious but it works well and is safe if you stay on high alert about not mistaking reverse for forward when you are close to the water.
/ Wheel spacers or weights for slopes? #122
Just saw this thread... We also have a L3800HST 4WD, but we have R4 tires, and the R4 wheels on a L3800 can't be adjusted for width ...
Can u swap sides with your tire / wheel ?
I swapped left front ovr to the right front & vise versa - keepin the tires turning the same direction.
My JD rim centers were offset & made a needed wider stance.
/ Wheel spacers or weights for slopes? #123
No, we can't swap the rear wheels with the R4 tires. The rear wheels on the L3800 that have R1 tires can be changed around. They have different wheel rims. When we bought the L3800, I saw that the next size up in the Kubota L series had rear wheels that could be adjusted even with the R4 tires, but not the L3800. Our M5700 had several positions the rear wheels could be adjusted to. We had them all the way out to provide maximum stability. The L3800 felt very unstable in comparison, which is why I started investigating wheel spacers.
/ Wheel spacers or weights for slopes? #124
If all else fails, resort to a good wide front mount mower with 4 WD like the Kubota's or Toro's to mow those hills.
Gotta be honest, it's not in those mowers either. I've got a 328 with 4wd and the front tires are flipped around for a wider stance. This thing will crab pretty good on a 25 degree slope. I'm not sure how steep it was, but I got myself into a real pickle the other day. I was trying to mow above a retaining wall and approached it from the opposite direction than I usually do. There is a short segment where the grade really pitches down towards the wall. That darn mower was moving forward, but it was crabbing so bad that I was getting too close to the wall. Because of the crab, I couldn't turn up hill without the back tires going over either. I ended up punching the uphill wheel brake and that was enough to get the machine out of the spot. Even then, I've already had 3-4 incidents where I lost traction and the machine slide or didn't react the way I wanted. Buried the mower deck under a massive rose in the front yard once. Thankfully it was a front deck and I didn't get tangled in the thorns. I think part of the problem is the 4wd clutch. It just takes too long for 4wd to engage. When I get a chance, I'll convert the machine over to full time 4wd.
If I had to do it all over, I'd go with the Toro 3500 or Deere 7400. Those machines are factory rated for 25 degree slopes. But look at the width vs height of them. Big difference.
/ Wheel spacers or weights for slopes? #125
I put the spread on mine. Just need some Massey suitcases.
/ Wheel spacers or weights for slopes? #126
Greetings Vtsnow, turf issues might not be your concern, but they were for number9's point of view as he stated . . plus if you are ripping turf you are losing the traction stability beneath you. And certainly traction is all of our concerns and tire profile of an ag tire vs turf tire on a sidehill advantages the turf tire for roll over concerns (side hill).
But for all the science type of center of gravity ( COG) physics . . . I had mentioned when a unit adds either front torsion leverage or rear torsion deflection . . COG is also only part of the story. Often times in our battles to defeat gravity on tractors or motorcycles or atv or bicycles for that matter . . forward momentum (or inertia) helps keep people upright . . . And the loss of that inertia or a forced slowdown of that inertia hurts your "staying upright". A fel on a sidehill or a brush hog behind on a sidehill causes drag on inertia and torsion twist because of gravity. Those implements are at the influence of gravity . . and they are being "pulled down" while we are trying to go sideways on hills.
A mid mount mower or a "direct side" batwing can aid in keeping you upright on a sidehill . . but a fel or trailer/3 pt attachment is never your sidehill friend in the effort at staying upright. You might stay upright in spite of them . . but not because of them.
Those who say COG is the only thing that keeps you upright have apparently never seen a motorcycle race or driven a motorcycle where COG is regularly and continually defeated by "a controlled" momentum or forward inertia . . and the rider continues upright while their COG is far outside their wheels.
Would you put out some examples with the math to demonstrate your point?
Tractors are not motor cycles and when driven by intelligent operators never experience G forces sufficient to cause roll overs. ( YES I know idiots roll them doing J turns on highways on a regular basis.
But to determine the maximum slope a tractor can work on safely you have to assume a prudent slow speed. Cowboys can roll anything on a flat parking lot given enough horse power and speed but if you want to get the weeds mowed on a steep slope you need a setup that is stable in parked position and not needing forward momentum to keep it from rolling over.
/ Wheel spacers or weights for slopes? #127
Examples "with the math" is am interesting response. When center of gravity is calculated in a vacuum of any other issues except gravity . . you can have a pure geometric relationship. but when you add in centrifical force . . then center of gravity takes on a different relstionship. "Speed " in your post assumes fast . . while speed in my post assumes movement. So here's an example many people can identify with. Take an 800 pound motorcycle and a 200 pound driver and try to keep it upright (and not feet/foot on the ground . . going 1/2 mile per hour - Virtually no one can do it by "balancing". But let the driver go 2 miles per hour and most bikers can keep it upright. Its because motion helps stabilize gravity's pull to some extent.
Just today I was cutting a sidehill in a downward direction (compound angle). With 3 mph speed . . The focus is on continueing the movement direction. If I'd be going only 1 mph gravity effect on the sidehill takes over. Similarly had I gone up the incline while sidehilling . . Gravity intensifies the battle and wins because momentum is slowed to meaningless gain.
"G forces" is not an equal to forward momentum in the gravity issues . . unless you want to refer to a fraction of g force.
Similarly . . in that same sidehill example . . in that very same location going the same speed . . if I had a fel on the front or pulling a trailer on the back . . I could never maintain a straght line of direction and also stay upright. Why? Because gravity's pull overcomes direction momentum when there is a drag on that momentum.
This also is exactly why a big bump or hole can play heck with sidejill movement . . because it alters forward momentum.
/ Wheel spacers or weights for slopes? #128
AxleHub, while I am with you in spirit... I am having a hard time believing that the slow speeds we are talking about while mowing are going to significantly affect (counteract) the effect of gravity. Your argument while theoretically correct is not realistic for the case at hand in my opinion. The math can be done but your motorcycle analogy is flawed. The rider leaning over to the side is 'fighting' angular momentum not linear momentum. I don't care how fast you are going in a straight line, you can't 'lean' over such that the C of G of the combined weight of you and the vehicle are outside the footprint for long and remain upright... I take that back, you could be flying. :D
/ Wheel spacers or weights for slopes? #129
I wouldn't ever want to be in a position or on a slope where I could not come to a stop or change directions without tipping over.
/ Wheel spacers or weights for slopes? #130
Try leaning a motorcycle over to turn while traveling under 5 mph and let us know how much dynamic stability you experience.
Tractors at typical hillside mowing speed depend primarily on COG. The only significant "dynamic" forces of importance are bumps and holes that raise uphill or downhill wheels suddenly.
/ Wheel spacers or weights for slopes? #131
Greetings Dragon. I believewe are talking about two different examplesas if they are the same thing. One is about centrifical force (leaning in when speed allows centrifical force) . . . the other example is momentum in a straight line even at very low speeds that allows continuing operation.
/ Wheel spacers or weights for slopes? #132
Vts. Some people are comfortable with hills and some aren't. In a 5 mile drive yesterday . . . I saw three different people at three different locations mowing their lawns in places where they could not have come to a complete stop or safely changed directions. In my own small neighborhood there are numerous lawns that have at least one or two areas in each could say the same.
Its not dangerous . . its just normal cautious 15 and 20+ degree lawn mowing. You don't cut those areas wet or with dew on them.
/ Wheel spacers or weights for slopes? #133
Greetings Island, you don't do much "leaning " on a bike at 5 mph. But you also don't do alot of manual pushing of an 800 or 1000 pound bike either. At 5 mph an experienced rider can keep a motorcycle upright and moving pretty well. I specifically used the couple of motorcycle examples because there are only 2 wheels so everyone can envision center of gravity issues.
And I agree with much of your statement when you said " Tractors at typical hillside mowing speed depend PRIMARILY on COG." I believe that is a logical and reasonable statement anf I capitalized the important variable.
But some make sweeping statements of absolutes. And COG . . while important . . Is only one part of the story. Issues like ground traction, tire style/kinds/pressures and tractor momentum or reduction of lateral forces are other issues all effect keeping a tractor properly upright on hills. I read too often in threads . . where posters say a low fel or a rear brush hog helps benefit COG stability on hills and those types of statements may lead others to do unsafe actions. Fels and tow behinds are used on hills in spite of COG.
My personal operating style on hills changes greatly when I have my fel on front or something on my 3pt or pulling something . . its a night and day difference in speed and pitch that I'll work on.
/ Wheel spacers or weights for slopes? #134
With 44 Vermont winters behind me while driving every type of car or truck there are I've used momentum a lot to make it to the top of the hill and have been careful to not have too much when the icy curve would send you off into the snow bank or brook. So I understand what your saying just don't think it matters much at mowing speeds of 2 to 4 mph. And yes some people have sections of lawn they mow by climbing up a side grade then straight down the steep part the mower can 't come back up . All right if there is a good clear area to stop in at the bottom. I leave such areas as woods.
/ Wheel spacers or weights for slopes? #135
I just mow strait up, then back down both in 4wd, and I can't do that if grass is wet LoL
Takes a Lot of traction & power to drag the 1,450lb RFM up steep banks at my Poultry Farm.
/ Wheel spacers or weights for slopes? #136
I can see where a bush hog could lower COG and be beneficial, so I won't dispute this claim one way or another. But I don't think I have ever seen a tractor where the FEL would be beneficial on a hillside for any reason. The COG is almost irrelevant in this case because even on a scut like a BX you have transferred a few hundred pounds off the stable rear axle to the tippy front axle. If the bucket is full of rock and an inch off the ground you have certainly lowered the COG but you have moved several hundred or even thousands of pounds forward to the rocking front end. Yes you should ballast to compensate for this, but the mere presence of the FEL is never going to be helpful for stability.
/ Wheel spacers or weights for slopes? #137
The FEL certainly doesn't add stability but sometimes you just need it. If all you do is mow well cared for fields then it probably should be taken off but some of us mow/bush hog in areas where the FEL is used to feel ahead of the tractor and to remove obstacles. I mowed for four hours today and had to move half a dozen fallen trees and numerous big branches as well as a new spring crop of good sized rocks. Could not have gotten the job done without a grapple.
/ Wheel spacers or weights for slopes? #138
I think that makes a lot of sense . . especially if the land is relatively flat . But how do you do this if you're on a steep hill?
/ Wheel spacers or weights for slopes? #139
Tippy front axle? Well I suppose having the FEL on does move the COG forward and front axles are somewhat or in my case a lot narrower then my rears so the COG is then closer to one of the side roll over tipping lines. but when you consider end for end flips the FEL is an advantage greatly reducing the tractors tendency to pop a wheely or go completely over backwards and making a front end for end flip almost impossible if the bucket is held low.
I've never taken my loaded off and probably never will.
/ Wheel spacers or weights for slopes? #140
You simply don't traverse steep hills in a CUT. Up and down. Hopefully with a flat area on top to let you turn around. I sometimes make ten point turns if necessary on slopes as guided by my sphincter.
Red Oak Boards (A65640)
Red Oak Boards...
John Deere 4955 (A64126)
John Deere 4955...
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
