What the **** is that!
   / What the **** is that! #1
gregweirauch
Michigan
none
Ok got running gear and that is about it. Ordered bed lumber (white oak) and beams. Need a big box of big carriage bolts this locks and nut, just need to go get. rims at tire store for used tires. With running gear came what looks to be u- channel steel sheet metal side edging. It has stake pockets in it? it is about 4 inches all three sides and has little tabs by some of the holes. It is in pretty good shape but not sure how to use it. Will post pictures when I get home. Little help?
G
   / What the **** is that! #2
is it fairly heavy wall stuff? like quarter inch thich. Without a picture I'm just guessing but it might be a bolster for one end of rack. It would be mounted on one axle so it can rock when the tires are in a deadfurrow or hole, like a teeter totter. That's my guess.
   / What the **** is that! #4
Another welcome! This one, from Texas!
   / What the **** is that! #6
:welcome: to :tractor: by net
   / What the **** is that! #7
Welcome, I've learned a lot here in two months. Mostly I've learned I have a lot to learn. Are you a long time tractor owner or new to all this? Either way I'm sure you will enjoy this site.
Photos I hope
https://www.facebook.com/photo.php?fbid=10202130647696230&set=pcb.10202130649376272&type=1&theater
https://www.facebook.com/photo.php?fbid=10202130649016263&set=pcb.10202130649376272&type=1&theater
https://www.facebook.com/photo.php?fbid=10202130648136241&set=pcb.10202130649376272&type=1&theater
https://www.facebook.com/photo.php?fbid=10202130648336246&set=pcb.10202130649376272&type=1&theater
Nah 12 gauge of less sheet metal really, like a rub rail 16 ft long u channel with stake holes to hold the sides I guess. I would like to have the stakesides available and can make them no problem but if I attach the edging to the deck planking the holes will be filled in by the decking Should I notch the 1"decking to make room for the stakes to slip thru or drill it out I wish I could seen how it was done back in the day. Please see pictures uploaded below
Thanks
G
2020 DRAGON ESP...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2014 Nissan Rgue SUV (A59231)
2014 Nissan Rgue...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
2022 Ford F-450 Liftmoore 5000W Crane Service Truck (A59230)
2022 Ford F-450...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
