What the **** is that!
   / What the **** is that! #1
gregweirauch
Michigan
none
Ok got running gear and that is about it. Ordered bed lumber (white oak) and beams. Need a big box of big carriage bolts this locks and nut, just need to go get. rims at tire store for used tires. With running gear came what looks to be u- channel steel sheet metal side edging. It has stake pockets in it? it is about 4 inches all three sides and has little tabs by some of the holes. It is in pretty good shape but not sure how to use it. Will post pictures when I get home. Little help?
G
   / What the **** is that! #2
is it fairly heavy wall stuff? like quarter inch thich. Without a picture I'm just guessing but it might be a bolster for one end of rack. It would be mounted on one axle so it can rock when the tires are in a deadfurrow or hole, like a teeter totter. That's my guess.
   / What the **** is that! #4
Another welcome! This one, from Texas!
   / What the **** is that! #6
:welcome: to :tractor: by net
   / What the **** is that! #7
Welcome, I've learned a lot here in two months. Mostly I've learned I have a lot to learn. Are you a long time tractor owner or new to all this? Either way I'm sure you will enjoy this site.
Photos I hope
https://www.facebook.com/photo.php?fbid=10202130647696230&set=pcb.10202130649376272&type=1&theater
https://www.facebook.com/photo.php?fbid=10202130649016263&set=pcb.10202130649376272&type=1&theater
https://www.facebook.com/photo.php?fbid=10202130648136241&set=pcb.10202130649376272&type=1&theater
https://www.facebook.com/photo.php?fbid=10202130648336246&set=pcb.10202130649376272&type=1&theater
Nah 12 gauge of less sheet metal really, like a rub rail 16 ft long u channel with stake holes to hold the sides I guess. I would like to have the stakesides available and can make them no problem but if I attach the edging to the deck planking the holes will be filled in by the decking Should I notch the 1"decking to make room for the stakes to slip thru or drill it out I wish I could seen how it was done back in the day. Please see pictures uploaded below
Thanks
G
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
Deere 333E (A60462)
Deere 333E (A60462)
