What the **** is that!
/ What the **** is that! #1
gregweirauch
Michigan
none
Ok got running gear and that is about it. Ordered bed lumber (white oak) and beams. Need a big box of big carriage bolts this locks and nut, just need to go get. rims at tire store for used tires. With running gear came what looks to be u- channel steel sheet metal side edging. It has stake pockets in it? it is about 4 inches all three sides and has little tabs by some of the holes. It is in pretty good shape but not sure how to use it. Will post pictures when I get home. Little help?
G
/ What the **** is that! #2
is it fairly heavy wall stuff? like quarter inch thich. Without a picture I'm just guessing but it might be a bolster for one end of rack. It would be mounted on one axle so it can rock when the tires are in a deadfurrow or hole, like a teeter totter. That's my guess.
/ What the **** is that! #4
Another welcome! This one, from Texas!
/ What the **** is that! #6
:welcome: to :tractor: by net
/ What the **** is that! #7
Welcome, I've learned a lot here in two months. Mostly I've learned I have a lot to learn. Are you a long time tractor owner or new to all this? Either way I'm sure you will enjoy this site.
Photos I hope
https://www.facebook.com/photo.php?fbid=10202130647696230&set=pcb.10202130649376272&type=1&theater
https://www.facebook.com/photo.php?fbid=10202130649016263&set=pcb.10202130649376272&type=1&theater
https://www.facebook.com/photo.php?fbid=10202130648136241&set=pcb.10202130649376272&type=1&theater
https://www.facebook.com/photo.php?fbid=10202130648336246&set=pcb.10202130649376272&type=1&theater
Nah 12 gauge of less sheet metal really, like a rub rail 16 ft long u channel with stake holes to hold the sides I guess. I would like to have the stakesides available and can make them no problem but if I attach the edging to the deck planking the holes will be filled in by the decking Should I notch the 1"decking to make room for the stakes to slip thru or drill it out I wish I could seen how it was done back in the day. Please see pictures uploaded below
Thanks
G
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
Welcome to the Ranch Metal Decorative Sign (A64557)
Welcome to the...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
REDDICK OFFSET DITCHER, 3PT (A64278)
REDDICK OFFSET...
2012 Freightliner M2 106 S/A 14ft. Cab and Chassis Truck (A64194)
2012 Freightliner...
2009 Peterbilt Pac-Mac KBF-20H Forestry Grapple Truck (A64556)
2009 Peterbilt...
