What the **** is that!
   / What the **** is that! #1
gregweirauch
Michigan
none
Ok got running gear and that is about it. Ordered bed lumber (white oak) and beams. Need a big box of big carriage bolts this locks and nut, just need to go get. rims at tire store for used tires. With running gear came what looks to be u- channel steel sheet metal side edging. It has stake pockets in it? it is about 4 inches all three sides and has little tabs by some of the holes. It is in pretty good shape but not sure how to use it. Will post pictures when I get home. Little help?
G
   / What the **** is that! #2
is it fairly heavy wall stuff? like quarter inch thich. Without a picture I'm just guessing but it might be a bolster for one end of rack. It would be mounted on one axle so it can rock when the tires are in a deadfurrow or hole, like a teeter totter. That's my guess.
   / What the **** is that! #4
Another welcome! This one, from Texas!
   / What the **** is that! #6
:welcome: to :tractor: by net
   / What the **** is that! #7
Welcome, I've learned a lot here in two months. Mostly I've learned I have a lot to learn. Are you a long time tractor owner or new to all this? Either way I'm sure you will enjoy this site.
Photos I hope
https://www.facebook.com/photo.php?fbid=10202130647696230&set=pcb.10202130649376272&type=1&theater
https://www.facebook.com/photo.php?fbid=10202130649016263&set=pcb.10202130649376272&type=1&theater
https://www.facebook.com/photo.php?fbid=10202130648136241&set=pcb.10202130649376272&type=1&theater
https://www.facebook.com/photo.php?fbid=10202130648336246&set=pcb.10202130649376272&type=1&theater
Nah 12 gauge of less sheet metal really, like a rub rail 16 ft long u channel with stake holes to hold the sides I guess. I would like to have the stakesides available and can make them no problem but if I attach the edging to the deck planking the holes will be filled in by the decking Should I notch the 1"decking to make room for the stakes to slip thru or drill it out I wish I could seen how it was done back in the day. Please see pictures uploaded below
Thanks
G
New Holland 650 Hay Baler (A53317)
New Holland 650...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
John Deere 5105M (A53317)
John Deere 5105M...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
