Grapple what size grapple
/ what size grapple #1
sailingsolo
hope, me
kubota L47
dealer sells land pride grapples. he recommended an sgc1560 and that was what i was going to buy. then the dealer says he can not get that one until late may but he can get an sgc1572. will be using on a 2018 l47 tlb kubota. would you go with the sgc1572 instead? it is one foot wider and 100 pounds heavier. do not need the grapple right now so there is no rush to get one of either size. bottom line, which grapple would you buy?
/ what size grapple #2
Have you check EA for a grapple, Everybody will say something different The l47 will lift 2800lbs so it really wont matter with the extra 100lbs
/ what size grapple #4
Yep. Their grapples are popular on this site and are well made (I have one).
Keep in mind that grapples with long lower tines extend out from the tractor farther than a bucket. When making a turn the grapple will run into stuff when a bucket the same width would not. If you're operating in tight areas you might want a narrower grapple because of this. Also the material you're picking up makes a difference- for things like logs a wide grapple isn't much of an advantage.
/ what size grapple
so how do you like your l47 tlb? i have used an l35 tlb and this is what sold me on the l47 tlb. forgot to ask, do you have a grapple, and, if so which one. i am looking at the land pride because of 0% financing.
/ what size grapple #7
I like it only 50 hours so far , No grapple I have the 4-1 bucket I use my l3800 more in the winter because I have the Agrex Tractor PTO Fertilizer Spreader with sand in it for the winter
/ what size grapple #9
2022 EZ-GO ELITE...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
2005 Little Wonder High Output Walk-Behind Blower (A64553)
2005 Little Wonder...
2001 102"X53' WEST STEP DECK TRAILER (A65054)
2001 102"X53' WEST...
2021 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2021 Chevrolet...
2010 HINO 268 4X2 S/A NON CDL 26FT BOX TRUCK (A67148)
2010 HINO 268 4X2...
