What did you do for your tractor today?
   / What did you do for your tractor today? #91
Maddening when you do something like that but it is part of life. At least you know what to do. Twice I have started my dozer then begun greasing or gone off to get some tools when all of a sudden I hear the revs increase then it dies. Like you say, DOH, I forgot to turn the manual fuel shut-off valve on that is on the under side of the fuel tank. On that I have to fill the fuel filter and crank until I get good air free flow and then bleed at the injection pump and it will start.
gg
   / What did you do for your tractor today? #92
I changed the high pressure transmission filter.
I made a footrest. Been wanting a footrest for my left foot when mowing, or road grading because of my bad back. Years ago I discovered that a higher shorter reach footrest helps with my sciatica problem on long hauls.
I'm calling it a beartrap design. Hope to get some use soon. :)
   / What did you do for your tractor today? #94
Nice job Scootr!
   / What did you do for your tractor today? #95
Today I ordered some works lights with strobes. I found out last week after the time change how useless my headlights are for FEL work. Got a set for each side of the ROP,s. Ill wire the strobes to work with my four ways for road travel. Also ordered a Speco quick hitch.
   / What did you do for your tractor today? #96
Not today but last Sunday I got about 5 hours of seat time on mine.. Looked at the hour meter and Im at about 350 hours.. About due for front tires real soon. I used it with the grapple picking up tree limbs and a bunch of sea grasses we cut down every year.
   / What did you do for your tractor today? #97
Added 1.5qt of 80w90 to the front axle
350 hrs isn't many hours for a set of tires.
I added an amber strobe light to my parking brake warning circuit. Mounted it where you could not miss seeing it when I climb onboard. More than once I failed to remember it was on or see the tiny dash light - especially when the dash is covered in dirt.
Toro Groundsmaster 3500-D Rotary Mower (A56857)
Toro Groundsmaster...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2012 International Derrick Digger (A55973)
2012 International...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
