What did you do for your tractor today?
   / What did you do for your tractor today? #91
Maddening when you do something like that but it is part of life. At least you know what to do. Twice I have started my dozer then begun greasing or gone off to get some tools when all of a sudden I hear the revs increase then it dies. Like you say, DOH, I forgot to turn the manual fuel shut-off valve on that is on the under side of the fuel tank. On that I have to fill the fuel filter and crank until I get good air free flow and then bleed at the injection pump and it will start.
gg
   / What did you do for your tractor today? #92
I changed the high pressure transmission filter.
I made a footrest. Been wanting a footrest for my left foot when mowing, or road grading because of my bad back. Years ago I discovered that a higher shorter reach footrest helps with my sciatica problem on long hauls.
I'm calling it a beartrap design. Hope to get some use soon. :)
   / What did you do for your tractor today? #94
Nice job Scootr!
   / What did you do for your tractor today? #95
Today I ordered some works lights with strobes. I found out last week after the time change how useless my headlights are for FEL work. Got a set for each side of the ROP,s. Ill wire the strobes to work with my four ways for road travel. Also ordered a Speco quick hitch.
   / What did you do for your tractor today? #96
Not today but last Sunday I got about 5 hours of seat time on mine.. Looked at the hour meter and Im at about 350 hours.. About due for front tires real soon. I used it with the grapple picking up tree limbs and a bunch of sea grasses we cut down every year.
   / What did you do for your tractor today? #97
Added 1.5qt of 80w90 to the front axle
350 hrs isn't many hours for a set of tires.
I added an amber strobe light to my parking brake warning circuit. Mounted it where you could not miss seeing it when I climb onboard. More than once I failed to remember it was on or see the tiny dash light - especially when the dash is covered in dirt.
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2017 Ford F-650 Stakebody Flatbed Truck (A53422)
2017 Ford F-650...
2022 John Deere 5065E MFWD Tractor (A53485)
2022 John Deere...
