What Causes Fishtailing?
/ What Causes Fishtailing? #41
If you have equalizing shackles, "raking" the trailer to the rear does not load the rear axle more.
/ What Causes Fishtailing? #42
Reg is right about the dynamics at work in a rear-loaded trailer. In airplanes tail-wheel airplanes are notorious for "ground-looping," where the aircraft rotates around the main landing gear in a spinning fashion. The center of gravity is behind the wheels, and wants to be in front, where the tires are being drug, rather than pushed. Darts are similar, too: if you throw one backwards, the heavy tip will rotate so it leads the resistance of the fins.
If you drive your car backward and steer, the center of gravity follows the steering tires and tends to exaggerate the movement, and will make it keep steering more in that direction. It's a positive feedback cycle, and is why rear-steering things are so squirrely.
The trailer wobbles when loaded to the rear for the same reasons. The center of gravity is behind the resistance of the tires, and has a pivot point at the hitch. It goes sideways, then force builds up in the springs, tires, and frame. If the tires don't skid, eventually those forces will bounce the trailer back the other direction, and the cycle starts over again.
This also explains why accelerating can sometimes stop the wobble, and braking usually makes it worse. Under acceleration the center of gravity will tend to be in line with the direction of pull, or straight. Under braking, the the center of gravity tries really hard to get in front of the resistance to its momentum.
That's oversimplified, but close enough to the principles at work.
/ What Causes Fishtailing? #43
Our issue was a tilt trailer. 96 Dodge 3/4 ton extended cab pulling a 16' tilt car hauler with about 3 ton of hay. We were coming down the on ramp to the freeway when it started swaying and by the time everything was done we had half the load blocking both eastbound lanes of I90. That was the last time he used a tilt trailer.
I think my BIL's drivers seat still has a crease down the middle of it.
/ What Causes Fishtailing? #44
You would hope so and might even think so.
Unfortunately, as with so many engineered things they're a "not quite" device, e.g. "Amplifiers oscillate and Oscillators don't"
Equalizers don't.
They come close, but they don't quite "equalize".
The "proof" of this of course is our friendly weigh station.
Weigh it axle by axle, then raise the ball an inch (assuming you have a hitch head with multiple positions) weigh it axle by axle again, including the truck.
Further proof, if needed, can be found on the highway if you make the suggested rest stops and circle checks.
The rear tire SHOULD BE detectably warmer than the front one on the same side.
Try it some time as soon as you stop, not after the break.
BTW, the position of the C of G can be easily calculated from the tongue load.
If the tongue load is 10% then the C of G is 90% of the way back from the coupler.
15% it is 85% of the way back, etc.
Run a tape back from the coupler to see where that is, ahead of the front axle is the usual answer.
/ What Causes Fishtailing? #45
Funny thing about darts - this is kinda sick, but we were kids.
There are few things more scary than having someone throw a dart at your face and you KNOW it is coming because they threatened to and did the three forearm aiming swings.
It takes a while, but somewhere around mid flight you realize that it is ONLY the flight that has been thrown - and it is DOUBLY SCARY if they throw it backwards, you just get a much bigger and more impressive visual of it as it turns around.
The whole thing is a "deer in the headlights" experience.
You KNOW it could take your eye out, you just can NOT cover your face or look away.
Just don't pass this sick trick onto the younger generation (-:
/ What Causes Fishtailing? #46
Reg, that's a funny story about darts. We were lucky enough to not every play that game. I can only imagine the laughter we'd have had, until mom caught up to us with the belt....:laughing:
Your advice to keep the load on the rear axle but with a forward CG is exactly right, and put into words something I "knew" from experience but never had to articulate. Thanks.
/ What Causes Fishtailing? #47
The '11 super duty has a brake controller that automatically activates to stop the 'wag' they had some utube videos,pretty impressive .
Talk about too much weight on the rear, ( no not the 'ol lady) I was with a guy one time and we were unloading a full size TLB on a gravel road that was quite steep. Guess we were in too much of a hurry to chock the wheels, boy did it get exciting when the truck tires came off the ground ! He kept with it and got off the trailer so everything got stopped before any injury or death !
/ What Causes Fishtailing? #48
Here's the "short" version;
Tongue load represents where the C of G is relative to the axles and hitch ball.
With very little tongue load the C of G is so far back that the trailer represents a teeter-totter, one that could go either way (unstable).
With increasing tongue load the C of G is farther forwards and is supported by the axles and hitch more like a bridge (more stable).
By maintaining proper ball height the "farther back bridge support" makes that bridge about 3ft longer.
Ya kinda hafta draw it out (-:
/ What Causes Fishtailing? #49
Just to play devils advocate, when on the scale, raise it to 6 inches then lower it back to 1 inch. You'll find trailer springs and shackles have a lot of friction in them which is why you don't need shocks. This friction will fool you into thinking you've loaded the rear axle more when you measure it your way.
To be fair, many equalizers are improperly installed so they will bias, or have very short shackles which will cause some bias when raked. These tend to cause problems like shackle flipping, binding, and rough ride too.
Equalizers don't.
/ What Causes Fishtailing? #50
I agree, that confusion would be likely if you were to do it statically while still on the scale - it is a mechanical analogue of hysteresis.
{Although at one time (the days of core memories) hysteresis was sometimes explained in similar mechanical terms (-:}
When doing this I have always had to "GET THE H311 OFF THE SCALE TO DO THAT !"
Then come back and roll on again for an axle by axle weighing.
Just turning around in the yard takes up the "sticktion" (sticking friction) that you refer to.
The slightly warmer rear tires are the "running proof" when on the road.
I stop every 3 hours and touch every tire.
Overly fussy ? Maybe, but I do know when a slow leak has started, a wheel bearing is unusually warm, a brake is dragging, or there is something else wrong in that area.
i.e. I have a very good idea of what is "normal" (for MY rig) at the wheel level.
/ What Causes Fishtailing? #51
In my experience, hot tires usually are from underinflation, but they surely would heat more with more load. I check them frequently too, especially when loaded heavy.
/ What Causes Fishtailing? #52
Equalizing shackles definitely help. They cannot compensate perfectly, but they're a tool that improves the situation. I dislike all the torsion axle trailers I've used because they don't have any equalizing ability. The only adjustments available are hitch height (fairly limited) and load positioning on the trailer (sometimes little to no variation available).
Torsion axles have some appeal in other ways, but for the widely variable loads I tow in shape, size, and weight I prefer equalizing shackles and leaf springs. Since it's easier to get proper load distribution with leaf springs that type of trailer tends to tow better for me, too. Something like a boat trailer, with the same load in the same place every time is a good candidate for torsion springs in my view.
/ What Causes Fishtailing? #53
Actually torsion axles on boat trailers stink. They were a fad in the late 90's till about 2002 or so. I would say tire blow outs were 5 to 1 on torsion equipped trailers.
The issue with a boat is while it may be the same load each time what people put in them is not. Fuel on a 23' boat I just sold could weigh anywhere from 0# if empty to 750# if full. Water tank could be 300# plus or minus. Same thing with the holding tank.
Give me regular axles any day of the week, torsions stink.
Chris
/ What Causes Fishtailing? #54
Diamondpilot, that's a good observation. The barefoot ski boat on a torsion axle trailer I've had experience with only weighs a little bit more than the full fuel and water tanks you mentioned. The weight is quite constant and doesn't vary that much. The fuel tanks are directly over the axles, as is the passenger and storage compartments of the boat.
The trailer has been no trouble at all, and pulls great, no flats or anything. And, the whole load hardly weighs anything, and is optimized to that. It's a particular situation that the torsion axles work well for, but they aren't really better than leaf springs would be. The only "benefit" is the springs aren't squeaky.
/ What Causes Fishtailing? #56
They sure ride rice though!
They do, and its a great idea but they just have no way to equalize the load like a conventional setup. Single axle trailer they would be great.
Chris
/ What Causes Fishtailing? #57
Great thread, I think I learned some things.
What about the towing vehicles tires. I remember riding in a truck 30 years ago and we blamed the tires sidewalls at that time for a lot of the problems we were having that day. I don't know about other brands but my Ford 150 came with tires rated for passenger cars instead of trucks.
Just wondering what the quality of tire plays in fishtailing?
Dan
/ What Causes Fishtailing? #58
Dan
Tires do play a part of it. I always go to some of the tire sites and read up on what I am buying. Its time for my neighbors 3rd set on his Dmax and the last set of Goodyears seemed to be soft. Sidewall stiffness is a big factor when you are towing 50% or more of the time and pulling something like a 14,000# camper.
Chris
/ What Causes Fishtailing? #60
I notice sidewall stiffness mattering more for the tow vehicle than the trailer with respect to fishtailing/trailer sway. Lifted vehicles, especially with tall tires, wobble more under influence from the trailer, and can induce sway. Electric brakes are nice, a quick tap bringing the trailer back in line with the tow vehicle.
2001 Ford F-150 4x4 Pickup Truck (A61568)
2001 Ford F-150...
2006 Nissan Pathfinder SUV (A61569)
2006 Nissan...
Honda UTV (A56859)
Honda UTV (A56859)
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
TEST YOUR BID BUTTON! (A62130)
TEST YOUR BID...
