welding table clamp
/ welding table clamp #1
joeu235
Platinum Member
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
I'm looking to buy a welding table and also some of the special clamps. This is a simple question but I can not find the answer. How do the clamps stay in the hole when clamping something down? Friction? Some kind of cam?
/ welding table clamp #2
If they are the ones I am familiar with, the table will have t-slots and the clamp with have a t-slot nut
/ welding table clamp #3
Real welding shops I know simply tack the work to the table and grind off the residue.
Also a professional weld shop make their tables with surplus or re cycled materials.
Hey, making a weld table is a darn good practice excersize.
/ welding table clamp #4
If you are talking about the F clamps that just fit into a round hole you just push down on them. The clamp deflects and puts pressure on the workpiece
/ welding table clamp #5
^^^DuckSlayer summed it up perfectly.
Here's my homemade clamps (typical 5/8" holes in table)
A mag drill makes it easy.
Terry
/ welding table clamp #7
You can buy the F clamps at Harbor Freight if you want, cut the ends off and weld on a bolt or rod like Big Barn did. Much cheaper. I'm going to make a few myself.
/ welding table clamp #8
If you want to go REAL cheap...... I bent up a couple of old tire irons. This one is shown in the pritchel hole of my anvil but they also work on my weld tables.
A LIGHT tap on the top secures the workpiece. An equally light horizontal tap releases it.
Terry
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
iDrive TDS-2010H...
1061 (A63291)
1061 (A63291)
2024 John Deere 5075E Tractor Loader (A63116)
2024 John Deere...
Woods HS106 Ditch Bank Mower (A63116)
Woods HS106 Ditch...
