welding table clamp
/ welding table clamp #1
joeu235
Platinum Member
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
I'm looking to buy a welding table and also some of the special clamps. This is a simple question but I can not find the answer. How do the clamps stay in the hole when clamping something down? Friction? Some kind of cam?
/ welding table clamp #2
If they are the ones I am familiar with, the table will have t-slots and the clamp with have a t-slot nut
/ welding table clamp #3
Real welding shops I know simply tack the work to the table and grind off the residue.
Also a professional weld shop make their tables with surplus or re cycled materials.
Hey, making a weld table is a darn good practice excersize.
/ welding table clamp #4
If you are talking about the F clamps that just fit into a round hole you just push down on them. The clamp deflects and puts pressure on the workpiece
/ welding table clamp #5
^^^DuckSlayer summed it up perfectly.
Here's my homemade clamps (typical 5/8" holes in table)
A mag drill makes it easy.
Terry
/ welding table clamp #7
You can buy the F clamps at Harbor Freight if you want, cut the ends off and weld on a bolt or rod like Big Barn did. Much cheaper. I'm going to make a few myself.
/ welding table clamp #8
If you want to go REAL cheap...... I bent up a couple of old tire irons. This one is shown in the pritchel hole of my anvil but they also work on my weld tables.
A LIGHT tap on the top secures the workpiece. An equally light horizontal tap releases it.
Terry
2023 Case TV380 (A62177)
2023 Case TV380...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
Set 4 - 10-16.5 tires on wheels for bobcat (A61572)
Set 4 - 10-16.5...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
