Welding table build
/ Welding table build #101
Structural codes, ASME codes, AWS codes, Military codes, etc., etc. Nobody would ever live long enough to go through all of them.
/ Welding table build #102
Glad I only build stuff for ME - I "glue" it together, try to break it, if I can't then it's to "code" :D
Built the saw stand, mountable either direction as guessed earlier:
Extendable support with height adjustment (which still needs a bit of work)
Cutting area built:
/ Welding table build #104
You've been busy!! :cool:
Looks like a very handy set-up. :drink:
/ Welding table build #105
What is the size of the cutting table? I like the diagonals, but might that ever be a drawback when cutting flatstock square to he table? What a great setup; I really like all the feature you have incorporated into it.
/ Welding table build #106
Looking good. Why use flat bar in cutting area on angle. I always seen angle iron used for that.
Thanks for the compliments.
The cutting area is 34" x 48" for an overall table size of 4' x 8' There's a 2" gap between the cutting area and the main table if I need to square cut anything.
Of all the tables I found while searching, I didn't once see one built with angle for the cutting area, all of them used flat stock. Not that they don't exist, I just didn't find any. Most of the CNC tables use flat stock bent into some form of an 'S' shape to eliminate the chance of a straight cut landing on top of a slat.
I had 4 reasons to build it on the diagonal:
1. The chance of a straight cut landing directly on top of one slat is almost ziltch.
2. When building stuff, narrow or on-edge pieces are more likely supported by multiple slats than falling in between them.
3. I've got a 2" overhang on the other 3 sides of the table and if I ran the slats straight, I wouldn't have the 2" overhang on the end.
4. I hadn't seen one built on the diagonal yet and wanted to be different
I still have to do something better for a bottom shelf, the OSB was handy and happened to be exactly the right size to fit between the legs and center support.
/ Welding table build #109
You might consider building a water box to go under the cutting table. It will help keep slag and hot sparks from flying around when using the plasma.
/ Welding table build #110
Or build a hopper and removable tray like I did for my burning table.
/ Welding table build #111
Did I mention how much I'm learning on this thread!!!! Thanks for the pics Shield Arc. I gotta have one of those!!!! :D
/ Welding table build #112
While your building, build one of these to burn circles with. Get a wheel off a truck or car, so you have bearings for the table to rotate smoothly. You'd be surprised how nice of circle you can burn with this.;)
No heat in the shop....would an ice box be of any use?
I'd already planned on some version of this. It will only collect the middle portion, not the 2" overhang but I don't expect to do much cutting in that area
Thanks for the idea. I've got a couple of old bearings off my wife's old car that would work well for that. When burning larger diameters, how do you keep the tip at the proper height from the material?
/ Welding table build #115
Now that Rocks!!!! So you punch a mark in the center of whatever plate you are cutting from, then attach the holder to the torch, put the sharpened tip in the punch mark and rotate the table???
Is the tightener that fastens the holder to your torch made from an electrical wire split nut connector???? How ingenius is that!!!!
Save both of those pics. :D
/ Welding table build #116
I wish I could take credit for this idea, but it's been around every since I started in the trade. Which tomorrow will be two whole weeks.:)
Yes they are electrical split nuts.;)
What I do is use a center punch to mark the center of the circle. Use a pair of dividers to scribe the circle. If I want the inside piece I start my cut on the outside of the scribe circle, once I punch through the plate I drag the point on the circle attachment to the center punch mark. If I want the plate with a hole in it. I start my cut on the circle and cut out to the scribe line letting the point on the circle attachment drop into the center punch mark. On real thick plate sometimes I'll even drill a hole so the torch starts easy.
/ Welding table build #117
Shield good ideas. It sounds like you been at it for more than two whole weeks.
/ Welding table build #119
The bottom key stock it tapped. I think I used something like a 10 x 24 cap screw cut the head off and ground a point on it. Find the height you like, use the jam nut to lock the 10 x 24 cap screw so it won't move on you. ;)
Not quite what I meant...that sets the initial height but what keeps the torch head from dragging? Been a long time since I've used mine and was only self- taught at that. I know you need to keep a bit of space between the tip and material with a plasma cutter, doesn't a torch work the same way?
2005 International 4400 S/A Day Cab Truck Tractor (A61573)
2005 International...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
generator trailer (A61569)
generator trailer...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
2007 Mazda 3 Hatchback (A61574)
2007 Mazda 3...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
