Welding table build
/ Welding table build #61
Thanks for posting the project pics Shield Arc.
Pretty amazing what a colony of ants can do. Also amazing what a colony of steel workers can do!!!!
/ Welding table build #62
Oh that's only a small % of the projects I've been on. But who ever thought of taking pictures. :laughing:
Last night got the main frame tacked together. Keep in mind, this is being built upside down.
The end where the welding shield is will be the cutting end. For now, I have to shift it back and forth on the plate as I'm working. If it weren't for the existing bow in the plate, I wouldn't have the long center support but the extra piece is easy enough to put in now
Practicing my vertical up welding:
Back of the weld: Decent penetration to my untrained eye
Also got the nuts welded into the bottom of the 2 legs. Not the prettiest job but I have no doubt they will hold
/ Welding table build #65
Thanks for the update with pictures. I look forward to your progress!!!
/ Welding table build #66
I would have made the frame a little differently but as long as it's straight and flat should be fine.
What would you have done different?
The reasons I did it this way may become (hopefully) more apparent as the rest comes together
/ Welding table build #69
I too, am interested in what you would have done, if you were building it. I am ready to buy the rest of the steel for mine (I already have the 28"x48"x 1/2" top). I've looked at so many build threads, and always wonder whether it is better to build a subframe, then weld the legs to the bottom of the frams, or to weld the up the frame tubes to the sides of the legs. I'm also considering whether to use box tubing, or 'C' channel for the frame. But this thread is about CDN Farm Boy's table, which I think is going to be a fantastic table. :thumbsup:
/ Welding table build #70
Your thread got me motivated and I was needing a project to test my new Powerarc 300 on.
I went to the steel yard Tuesday and bought a 4x10 sheet of 1/2" plate and 80' of 2.5" x 3/16 square tube. I laid the plate on the shop floor and built the frame on it upside down then flipped it over. Aside from the the metal I bought I added some 2" x 3/16" angle and a piece of pipe in the middle for support. Probably it is overkill but I wanted it sturdy and no flex. Weight of it is about 1400 lbs. I did not add any levelers on the feet or wheels but it sits good and level with no wobble. The thing is nice I don't think you could budge it if you wanted to. I am sure looking forward to being able to work on it and not on the floor anymore. My knees are killing me from this build.
Thanks Will S
Nice table bdog, I'm glad you got the incentive to build your own.
I got the legs and shelf supports tacked together this aft but my FD pager went off and didn't get any pics taken. Hopefully I get home tomorrow with enough daylight to get a bit more done and some more pics.
My main frame is attaching to the side of the legs for reasons you will see as the project continues.
/ Welding table build #72
Would you mind breaking down the costs on the top and tubing? I'm looking at buying a top from a surplus place. 5' x 11'8" x 1/2" sheet for $700
or a 4' x 8' x 5/8" sheet for $500.
/ Welding table build #73
Sure. I searched all over town for used or scrap plate with no luck so I had to buy new. The 4x10x 1/2 plate was $400.77 and the 80' of 2.5" x 3/16" tube was $284.53.
My 4' x 5' x 1/2" was a bit under $300 plus taxes. I also looked for used or surplus but found nothing suitable. My whole order was a grand with plan to have a few chunks left over.
The legs are inplace and about to spark up the old Lincoln and burn a few rods. Work is slow at the moment so it looks like I've got some time the next 2 days to work on it and hopefully get it wrapped up.
/ Welding table build #76
Looking good!
The hard part looks to be done you should be able to wrap it up in no time. You will love having the table. I have only had mine done a few days and everything is so much easier to do on the table vs rolling around on the floor.
/ Welding table build #77
Glad to see your progress. Thanks for posting the pics. Anxious to see the end result and "borrow" some ideas!!!
/ Welding table build #78
Just be sure not to overweld the top from the backside or you'll have little depressions or bows all over the table. Just scattered light tacking is all that you'll need.
/ Welding table build #79
Wow that was some great info in the previous pages about heat shrinking.
The plates I used to build my tables all had a slight bow in them too, but after I finished the tables were perfectly flat with a 6' straight edge laid on top. 4' x 6' tables I used 3/16" plate with 2" x 1/8" square tube for the frames. 1/2" plate might be more difficult to do this with but if you have strong c clamps it shouldnt matter. To remove the bow, once the frame for the table is built I'd lay the plate on it with the bow down. Then clamp the perimeter of the plate to your frame. If you have cross members in your ladder shape frame it should pull the bow out of the plate and with using 2 1/2" x 3/16" tubing I dont see there being a problem with the frame holding the plate straight after you tack it in. I highly doubt the pressure would distort your frame.
A couple hrs yesterday and a couple more this morning and I've got it ready to flip over. Once I got the slag chipped off, my stick weld beads look better than I expected. The plate was stitch welded about 1 1/2" bead on an approx 14 x 24 grid and alternated sides of the tubes to hopefully keep warping to a minimum.
Picked up a new attachment for the air hammer for chipping the slag. Anyone that hasn't tried a needle scaler needs to. Makes the job much easier
I've got about an inch both up and down from flat to adjust for uneven floors
700lbs each greasable wheels
Now to figure out how to flip it over since I can't get to it from the side, only the end......
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
JMR 72'' GRAPPLE (A61572)
JMR 72'' GRAPPLE...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
