welding helmet
/ welding helmet #1
sal64
Platinum Member
ny orange county
jd 2320 jd 990 jd950
hello all I have one of those auto adjust welding helmets is it safe for viewing the eclipse? thanks
/ welding helmet #2
If it adjusts to shade 12 or greater you can use it to view the eclipse
/ welding helmet
thanks for the response it does adjust to 12 im not familiar with this type of helmet if I look at a light it doesn't go dark if I get close to a light and turn it on quick it gets dark so if im looking at the sun will it darken abit? it is a little dark already like torch goggles
/ welding helmet #4
Really you want to trust your eyes to something you know nothing about? What if you don't cut it on quick enough when looking at the sun?
/ welding helmet #5
If it has a sensitivity adjustment turn it all the way down. It should darken just by looking outside if it's working. I think it should still darken looking at the sun either way. Try it without looking directly at the sun first.
/ welding helmet #6
As one who has lost part of my eye sight, do not take a chance with your sight for a few dollars. I will watch the eclipse on TV.
Walt Conner
/ welding helmet
thanks for the replies im not going to trust it I have an old welding helmet that's always dark I will use it .
/ welding helmet #8
Walt Conner
Or simply build a viewing box, which projects an image of the sun through a pinhole. It will take you only a few minutes, and it's 100% safe.
/ welding helmet #9
I doubt that hood will have a dark enough lens. Most welding is done with a #9 or 10 lens. My auto darkening hood ($300) adjusts up to 13 and I adjusted the sensitivity so it it darkens in just room light. That is the first time it has been above 11.
/ welding helmet #10
There was an ugly post about this a few days back. Lots of info there. read carefully. good luck !!
/ welding helmet #14
Do what you feel safe with but I put on my No. 5 cutting glasses, turned my Miller auto to shade 13, turned sensitivity all the way up so it darkens just being outside and gave a quick glance, I'm talking less than a second, the sun looked like a dim light bulb. That said, I'm still not sure I'm going to look at the eclipse, just don't seem right to look at the sun.
Massey Ferguson 9250 (A63688)
Massey Ferguson...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
Informational Lot - Shipping (A63689)
Informational Lot...
