welding helmet
/ welding helmet #1
sal64
ny orange county
jd 2320 jd 990 jd950
hello all I have one of those auto adjust welding helmets is it safe for viewing the eclipse? thanks
/ welding helmet #2
If it adjusts to shade 12 or greater you can use it to view the eclipse
/ welding helmet
thanks for the response it does adjust to 12 im not familiar with this type of helmet if I look at a light it doesn't go dark if I get close to a light and turn it on quick it gets dark so if im looking at the sun will it darken abit? it is a little dark already like torch goggles
/ welding helmet #4
Really you want to trust your eyes to something you know nothing about? What if you don't cut it on quick enough when looking at the sun?
/ welding helmet #5
If it has a sensitivity adjustment turn it all the way down. It should darken just by looking outside if it's working. I think it should still darken looking at the sun either way. Try it without looking directly at the sun first.
/ welding helmet #6
As one who has lost part of my eye sight, do not take a chance with your sight for a few dollars. I will watch the eclipse on TV.
Walt Conner
/ welding helmet
thanks for the replies im not going to trust it I have an old welding helmet that's always dark I will use it .
/ welding helmet #8
Walt Conner
Or simply build a viewing box, which projects an image of the sun through a pinhole. It will take you only a few minutes, and it's 100% safe.
/ welding helmet #9
I doubt that hood will have a dark enough lens. Most welding is done with a #9 or 10 lens. My auto darkening hood ($300) adjusts up to 13 and I adjusted the sensitivity so it it darkens in just room light. That is the first time it has been above 11.
/ welding helmet #10
There was an ugly post about this a few days back. Lots of info there. read carefully. good luck !!
66'' Skid steer bucket (A61567)
66'' Skid steer...
SANY SY35U EXCAVATOR (A59823)
SANY SY35U...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2002 WACKER RD25 ROLLER (A59906)
2002 WACKER RD25...
HYSTER S50FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S50FT...
