Welding helmet recommendation help please
   / Welding helmet recommendation help please #11
I used this vid when helmet shopping:
   / Welding helmet recommendation help please #12
I bought a low-end Miller ~$80 and used it for years.
A few years ago bought a Harbor freight unit on sale for ~$39 and it
sat on the shelf for a few years (in the box).
Then tried the HF because I was teaching someone to weld,
It is substantially better than the Miller.
You don't have to turn it on, it is solar powered, needs no battery.
The Miller has been on the shelf for a year now.
   / Welding helmet recommendation help please #13
Be aware....Solar powere helmets do have batteries... IF not exposed to ligh to keep internal batteries charged, the batteries die, and unit will fail.... I will not buy another unit that does not have replaceable batteries....
Dale
   / Welding helmet recommendation help please #14
Dale
I've heard that.
This HF hat was stored in the dark for years.
I've never paid attention to it's battery and it has worked fine.
That's about all I know.
   / Welding helmet recommendation help please #15
I've heard that.
My less expensive Metal Man hood, solar powered had two batteries sealed in AD unit.... Unit failed over time, tried to open up unit to troubleshoot battery issue, mistake, unit is sealed in such a way it gets pretty well destroyed trying to open it.... Contacted Metal Man, they have replacement AD unit that takes 2 AAA batteries.. IT also has "grinding" setting which old unit did not have and battery test button and all the usual AD "stuff"...
Dale
   / Welding helmet recommendation help please #16
Solar, with replaceable battery on mine.
   / Welding helmet recommendation help please #17
Have the AH260 antra as well the batteries even lasted over 2 years for me.
The antra is also a 4 sensor hood and works with every welding method has a grinding mode and even works for plasma cutting as well as low amp TIG which is accurately triggered with this hood.
Well ordered a Antra helmet.
Antra AH7-860-0000 Auto Darkening Welding Helmet Huge Viewing Size 3.86X3.5" Wide Shade Range 4/5-9/9-13 Great for TIG MIG/MAG MMA Plasma, Grinding, Solar-Lithium Dual Power, 6+1 Extra lens covers
Covers all the bases for me. replaceable batteries. light weight. LARGE viewing area. 1/25000 lens speed. 1/1/1/1 rated.
they also have replacement parts available as well.
Under $100.00.
Should do the trick...
Thanks for all the advise. you're the best
   / Welding helmet recommendation help please #19
Right on.
   / Welding helmet recommendation help please #20
In the future, for the benefit of others looking at this thread: Don't forget to look at the Jackson products. Most of them have an "old school" look. But they are good as they come on lens quality and features. Plus they are almost always easy to get on cover lens and replacement batteries (many have triple A).
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2015 Nissan Sentra Sedan (A55758)
2015 Nissan Sentra...
