Welding helmet recommendation help please
/ Welding helmet recommendation help please #1
Rebeldad1
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
over 70 and fighting to see a weld like a lot of you.
Never used a auto darkening helmet. Still old school. I'm sure (hoping) a auto darkening hood will help me start my welds where they are supposed to be. Dont do much welding anymore. Some stick, some wire feed.
Looking for a reasonably priced helmet. Doesnt need a lot of bells and whistles. Just something simple.
Reading some of the threads a must have would be a helmet I can get cheater glass for and adjustable shades of darkness. Possibly adaptable to a hardhat if needed? not a big issue.... just keeps a lot of splatter off the head.
Anything else?
A lot of you have gone through lots of helmets. Are there any common ones that stand out?
Thanks in advance!!!
/ Welding helmet recommendation help please #2
Take a look at usaweld.com and their “striker” brand helmets. They sell for around $140. With the display technology available today, you don’t need to spend more to get a wide, clear view, “grind” mode, variable shade, and reasonably comfortable headgear.
If $140 is over budget look at Eastwood.com I don’t have personal experience with these helmets but the reviews seem good.
/ Welding helmet recommendation help please #3
I started welding with a fixed shade small (2x4 or whatever the small size is). I was reluctant to go to an auto darkening hood, but finally gave in when I couldn't get my welds to start in the right place. It also had a larger lens. So! Auto darkening are the only way to go!!! My current helmet comes from tractor supply and has an adjustable shade as in I can turn a dial to get the shade I want. It also has a grind mode, and was under $100. I still have my fixed shade, but it's sitting on the shelf gathering dust.
I'm also over 70 and do mostly MIG anymore, but still use stick for some items.
/ Welding helmet recommendation help please #4
Several things not necessarily related to "new" helmet, though a AD helmet is really good for us oldsters...
Try with magnifying lenses in helmet, I find 2 diopter cheater lens really help.
Flood a lot of ambient light on area to weld, actually putting headlight on helmet helps....
Clean weld area very well and highlight bead line with white or silver marking paint stick.....
Edit to add: Go see opthamologist about if you have cataracts, I have had cataract surgery in both eyes and it helps immensely....
Dale
/ Welding helmet recommendation help please #5
This is what I have, <$40 on Amazon, it's great: Antra AH6-260-0000
#4-13 shade adjustment, sensitivity and delay adjustment, grinder mode, comes with a bunch of extra lense covers, and you could put magnifying lenses in there if you need them. Dunno how they stick all that into a 40 buck price tag, but it's a hella deal.
Quick edit: For some reason, this website is redirecting amazon links to ebay. Amazon has a better price on this, just go on there and look up the model number.
/ Welding helmet recommendation help please #6
Anything else?
At your age it is likely you wear glasses, you may have moved beyond the strength of drugstore reading glasses (and cheaters), and likely the prescription for each eye is different. I have all 4 problems. I normally wear progressive bifocals and find the magnification field is too small and close to the bottom of my field of view when wearing the helmet. I have tried wearing the glasses upside down when welding or doing overhead work; it is too cumbersome. My work-around is reading glasses that have the full magnification over the entire lens, and they work well for welding and overhead work like wiring. Middle and far distance acuity suffers but is okay for moving around the shop.
When I shopped for auto-darkening helmet I found the HD, HF, NT, and other cheap models were an order of magnitude slower than the Millers or the Arc One I bought. (1/2000 second vs 1/20000) I suspect the number of arc strikes left in these old eyes is limited, and the faster speed is warranted. Arc One is a Taunton, MA company bought at a local Air Gas dealer, not sure if it available where you are.
/ Welding helmet recommendation help please #7
I have an autodarkening and I have mixed views about it, especially if you'll be using it outdoors. More importantly is probably the use of a cheater lens if you need it.
/ Welding helmet recommendation help please #8
Cheater lens mounted inside your helmet was the best thing by far I did to improve my welding. Gotta see the puddle.
/ Welding helmet recommendation help please #9
Interesting timing: I just did an 8 minute video on welding hoods for my welding students this week. Usually I am always late to these kinds of questions! :thumbsup:
You will like an auto-darkening welding hood, so go right out and get one: you will not regret it.
Also, do not over-spend. My auto-darkening welding hood was bought at Harbor Freight for $50 last week. It does all I need it too. The cheaper welding hoods have only (2) sensors instead of (4) or even (6), but you only need that when you are doing mirror welding, pipe welding, or places where you are not always around the arc to get the helmet to trigger on. When I worked at a shipyard...welding 8 hours a day...yeah, a $400 welding hood was justified. As a welding instructor, or welding at home; a $50 one is just fine.
Another point: do not think that setting the shade higher or lower is going to save your eyes, or let you see better. Shade is about the intensity of the arc. I like to put my hood on 10 for stick or tig, 11 for flux-core, and for bare metal wire maybe 12-13. Putting your weld hood at 13 is not better, as it just makes you squint (and makes it hard to see your welds). But equally, setting the hood at say 9, makes it just as hard to see with too much arc light.
/ Welding helmet recommendation help please #10
But I did a companion video to welding hoods, about how to start welds. This was only in regards to stick welding, but here are (3) different methods you can use to allow a previously welded rod, to light up like it is a brand new rod, so you do not waste welding rod, or struggle to get it lit.
1. Flick your wrist IMMEDIATELY after stopping your weld. A ball of snot will fly off the end of the rod, and when you go to start it again, it will arc like a brand new rod.
(I do not like this method as it can start fires or burn other people, but it does work really well.)
2. The reason a rod does not restart like a brand new rod is because there is a little bit of flux protecting the metal filler of the rod. I like to take my gloved-thumb and gently break that bit of flux off the bottom of the rod before lighting it up again.
(I typically do this, but it can burn the thumbs off your gloves prematurely).
3. This is my favorite, and preferred method. Take a piece of wood, any wood, hard or softwood, and immediately after finishing your weld, put the still hot rod onto the wood and let it burn in for a second. That consumes that flux, and you can start your next weld as if that rod is brand new. Try it, it is amazing how well it works!
/ Welding helmet recommendation help please #11
I used this vid when helmet shopping:
/ Welding helmet recommendation help please #12
I bought a low-end Miller ~$80 and used it for years.
A few years ago bought a Harbor freight unit on sale for ~$39 and it
sat on the shelf for a few years (in the box).
Then tried the HF because I was teaching someone to weld,
It is substantially better than the Miller.
You don't have to turn it on, it is solar powered, needs no battery.
The Miller has been on the shelf for a year now.
/ Welding helmet recommendation help please #13
Be aware....Solar powere helmets do have batteries... IF not exposed to ligh to keep internal batteries charged, the batteries die, and unit will fail.... I will not buy another unit that does not have replaceable batteries....
Dale
/ Welding helmet recommendation help please #14
Dale
I've heard that.
This HF hat was stored in the dark for years.
I've never paid attention to it's battery and it has worked fine.
That's about all I know.
/ Welding helmet recommendation help please #15
I've heard that.
My less expensive Metal Man hood, solar powered had two batteries sealed in AD unit.... Unit failed over time, tried to open up unit to troubleshoot battery issue, mistake, unit is sealed in such a way it gets pretty well destroyed trying to open it.... Contacted Metal Man, they have replacement AD unit that takes 2 AAA batteries.. IT also has "grinding" setting which old unit did not have and battery test button and all the usual AD "stuff"...
Dale
/ Welding helmet recommendation help please #16
Solar, with replaceable battery on mine.
/ Welding helmet recommendation help please #17
Have the AH260 antra as well the batteries even lasted over 2 years for me.
The antra is also a 4 sensor hood and works with every welding method has a grinding mode and even works for plasma cutting as well as low amp TIG which is accurately triggered with this hood.
Well ordered a Antra helmet.
Antra AH7-860-0000 Auto Darkening Welding Helmet Huge Viewing Size 3.86X3.5" Wide Shade Range 4/5-9/9-13 Great for TIG MIG/MAG MMA Plasma, Grinding, Solar-Lithium Dual Power, 6+1 Extra lens covers
Covers all the bases for me. replaceable batteries. light weight. LARGE viewing area. 1/25000 lens speed. 1/1/1/1 rated.
they also have replacement parts available as well.
Under $100.00.
Should do the trick...
Thanks for all the advise. you're the best
/ Welding helmet recommendation help please #19
Right on.
/ Welding helmet recommendation help please #20
In the future, for the benefit of others looking at this thread: Don't forget to look at the Jackson products. Most of them have an "old school" look. But they are good as they come on lens quality and features. Plus they are almost always easy to get on cover lens and replacement batteries (many have triple A).
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
2013 Ford Escape SUV (A64557)
2013 Ford Escape...
2018 Chevrolet Silverado 3500 Royal Service Truck (A64194)
2018 Chevrolet...
Welcome to the Ranch Metal Decorative Sign (A64557)
Welcome to the...
John Deere Metal Decorative Sign (A64557)
John Deere Metal...
2014 Chevrolet Tahoe SUV (A64557)
2014 Chevrolet...
