Weights for beginners
/ Weights for beginners #21
One local tire store is or was loading them with used auto antifreeze for a low price. It's a great way for them to get rid of it; but there's no way that I would want it on my property. Get a slow leak and you're spewing that crap everywhere.
Yeah I read about people using RV water system antifreeze because it's non-toxic; the other will kill your dog fast.
WW fluid is cheaper than a 50lb bag of calcium and 40-50gal of water? I think I paid $25-30 for 50lbs of ice melt (calcium chloride) at the height of winter when I filled my tires.
WW fluid may cost more today, but the calcium may cost you more in the long run, depending on if you keep the tractor long enough for the calcium to destroy your rims or if it becomes someone else's problem...
Also, if you've got say a 12.4-28 tire, that's about 35 gallons of plain water per tire, or 27.5 gallons of water with 6 pounds of CaCl2 per gallon, or 138 pounds of calcium per tire, or six bags for both tires. It may cost more than $25 if you're actually trying to maximize your tire loading (75% fill for tube tires; for tubeless, increase by 20%) [source].
/ Weights for beginners #22
Torvy - you have to decide what is required based upon what you will be doing. Loader work - you will need some form of rear weight - wheel weights on the tires, fluid in the tires, something heavy on the 3-point. One or two or all three of these choices. Your Operators manual for your tractor should help. It could, like mine, indicate max load on the 3-point, max weight clapped on the rear rims, what fluid can be added to the rear tires for weight.
I've had two tractors. Brand new Ford 1700 4WD. It had a bucket on the FEL, CaCl in the rear tires( BIG mistake ) and a rear blade on the 3-point. This was enough weight to allow the tractor to lift max loads with the FEL.
My 2009 Kubota M6040 tips the grain scales @ 10,100 pounds. A grapple on the FEL, 1550# of RimGuard in the rear tires & a 1050# rear blade on the 3-point. I can lift all I will ever need with this combination. This is the way the tractor is set up about 95% of the time
One suggestion - do not add CaCl fluid to the rear tires for weight. Today there are fluids that are so much better. Meaning they do not cause extensive corrosion. RimGuard, windshield washer fluid, RV antifreeze, methanol.
/ Weights for beginners #23
I have driven many machines with loaded and even foam filled tires. I have never felt sloshing. You can and only really want to fill the liquid in the tire to just below the valve stem when it's at the 12 o clock possition.
I also have a old ford 851 that has loaded tires that are so dry rotted I'm suprised the tube is still in the tire yet they still are and I have driven over many stumps and sharp rocks with out even taking a valve stem out while useing it to clear brush.
Im aware of the correct level to load tires. Noticeable sloshing occurs when they are under filled with a low viscosity fluid like washer fluid. CaCl is a great way to rot out rims that dont have tubes. Im not running brine without tubes in a nearly new tractor and im not putting tubes in tires that dont need em. a 270 gallon tote of washer fluid cost us 330 dollars if the tote gets exchanged.
I agree - I wouldn't have a tractor w/o loaded rear tires. But I don't have a lawn to worry about like some.
gg
This would be my situation. No lawn. Probably bucket and/or grapple most of the time. Moving deadfall or thinned trees and branches.. some dirt work as well.. will have an RC, maybe a chipper.
Sounds like I need to learn more, too. Adding air is easy with a compressor. How do you get fluid into the tires? Any idea how much foam fill would run?
Thanks all for the good info!
/ Weights for beginners #25
I think we are mostly all talking about weight for a front end loader. Let's also not forget that wheel weights or balist in tires also helps when you have a 3pt attachment on and it's being driven through the ground. Once that attachment is on/in the ground the tractor may not carry its weight...yet the tractor will still need traction.
/ Weights for beginners #26
/ Weights for beginners #27
I just found this interesting "Ballast Calculator" spreadsheet for JD which allows you to punch in all of your applicable data, and apparently gives recommended weight needed. You would need to download the actual spreadsheet, the link is for demonstration purposes only.
/ Weights for beginners #28
So my next question by a beginner for beginners...
We hear a lot about weight, more is better, less is better, tires, suitcases, front, back, etc.
Ultimately, weight is a balancing act using your tractor as the fulcrum. Pick up a heavy load with your FEL and no weight in back and your back wheels may come off the ground or worse. Add too much weight and you can increase stress on structure and will definitely spend more money on fuel and potentially do more damage as you sink deeper in soil.
So, that's what I think I know...experts, here are my questions...
How do I know how much weight to add?
What is the best way to add weight?
What ways should be avoided?
What else do you think us beginners need to know about weight?
Thanks!
Start with your owners manual! You should find recommended weights for each situation weather with loader installed looking at rear ballast. Rear ballast can be from wheel weights, filled tires, and 3PH added weight (several options here as well, a frame to accept suitcase weights or ballast box including homemade and commercially available). If you remove the loader, you may need front ballast. There should be a related section in the owners manual here as well.
As long as your weight you add stays within the limits of your mfg recommendations, you should be find on structural limits of your tractor.
/ Weights for beginners #29
You’ll like liquid ballast until you have a leak.
Then you won’t like liquid ballast
/ Weights for beginners #30
See my post #14 in this thread. I had the same concern but went with a tire sealant that works with liquid ballast and used non-toxic RV antifreeze.
2018 VOLVO DD25B DOUBLE DRUM ROLLER (A62129)
2018 VOLVO DD25B...
2021 Kubota SVL75-2 Track Loader (A61307)
2021 Kubota...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
