weight box
/ weight box #1
tbarber
Ct
JD 855
My friend just built me a weight box out of 1/4 diamond plate
steel. The size is 24"x24"x16" . It is now filled with rocks.
My question is how much does this thing weigh ?
Just a guesstamit ? I have no idea, when I pick it up the rear tires squish down. The traction is great now especially with the box and tire chains.
/ weight box #2
5.2 cubic feet of volume. Crushed stone or cobbles? My guess 500 - 600 pounds.
/ weight box #3
I would guess about 400lbs if your talking pee stones for a filler.
/ weight box #4
Why don't you just take it to a scrap yard or landfill and get it weighed? Even if there's a charge it would be minimal. Then you'd know exactly how much it weighed.
/ weight box #5
Why don't you put the empty box on a bathroom scale, weigh the contents a bucket at a time and add them all up for a total?
/ weight box
Thanks guys. I was thinking it may have weighed more. I dont
think the wife would like the idea of using the scale. I'm to lazy to bring it somewhere to get it weighed, it was easier to ask.
/ weight box #7
Tom,
My Glover's pocket ref "weight of materials" table lists most types of dirt, gravel, and crushed or broken stone as weighing between 100 to 125 lbs per cu-ft depending on how much sand and/or moisture is mixed in.
So your 5.2 cu-ft holds 520 to 650 lbs of typical gravel / stone.
But don't forget to add the box itself. You don't say which side is 16", so the box (less brackets, pins, weld bead, etc) would be either 576 or 568 cu-inches of steel x 0.286 lb/cu-in equals 162 to 165 lbs.
I estimate your total would be between 682 and 805 lbs plus the welds and the additional brackets and hardware you don't describe in detail.
- Rick
/ weight box
Thanks thats all I wanted some idea.
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
2010 John Deere 4720 58HP 4WD Utility Loader Tractor w/ Titan Aerator (A66734)
2010 John Deere...
2013 MACK CHU613 (A67714)
2013 MACK CHU613...
WARREN POWER SYSTEM LIGHT PLANT (INOPERABLE) (A68842)
WARREN POWER...
2006 HONDA ACCORD (A65057)
2006 HONDA ACCORD...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
