weed eater/chopper string
/ weed eater/chopper string #1
tglass
Platinum Member
3320 w/cab
Anyone know of anything to use for a trimmer line? Tried cable and solid line with no results for any lenght of time. Hate to use a blade, but might be the best resort since I won't be off the machine if in motion. This is a 3-point hooked to the rear of a small tractor.
/ weed eater/chopper string #3
Piano wire? Guitar strings?
Even for small cable, use a welder to fuse the ends.
Won't fray so bad this way.
Got pictures of your setup. We wanna see it.
Pooh Bear
/ weed eater/chopper string #4
Pooh Bear
/ weed eater/chopper string #5
Heavy Square will work the best, will outlast any metal flex line. If that dont get it it is to steel blades.
/ weed eater/chopper string #6
Pics might take time, but tried cable welded on the ends, and yes it did frey under heavy load. Thing I didn't notice till today is before they did I not only trimmed along the shed, but also through it in a few places. Now it's an inch lower. Chain..possible but wouldn't it wind around the spindle when it starts? Square shaft might be to harsh if it hits something solid, plastic breaks too easy if in hard weeds, so I'm back to trying a plastic surrounded cable for rigitivity when starting and a welded end to prevent freying. Still have other problems with the Eater, (as I call it), like harsh recoil of the arm when deflecting off t-post, and the loss of hyd. to the motor when pulling or pushing the arm around bushes or small trees(also extendable). Think this can be overcome in time with everyones knowledge. Appreciate the support.
/ weed eater/chopper string #13
Get just the right length of chain-saw chain with the teeth pointing the right way and let'er rip. I had that setup on my "string" trimmer and I worked great.
Of course I never had a link fly off and inbed itself in my foot or ankle. /forums/images/graemlins/blush.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif
/ weed eater/chopper string #14
He..he.., What can I say about that? I already let'r rip and you should see the damage. Think of what other damage I could do around the place with a chain saw blade attached. Doesn't paint a pretty picture, but still might be worth trying. Anyone else have any of these minor problems? I Think Not, but like to hear about them.
/ weed eater/chopper string #19
I like the heavy square line.Wife has one of them chain heads on her old trimmer and I won't even gas it up!!! Hey ya'll...watch this.Might as well run around with scissors and play chicken with trains...
Ever wonder why the pros all have big spools of line hanging on the sides of their trailers?
/ weed eater/chopper string #20
2020 DRAGON ESP...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2014 Dodge Avenger Sedan (A59231)
2014 Dodge Avenger...
2021 Nissan Versa Sedan (A59231)
2021 Nissan Versa...
