weed eater/chopper string
/ weed eater/chopper string #1
tglass
Platinum Member
3320 w/cab
Anyone know of anything to use for a trimmer line? Tried cable and solid line with no results for any lenght of time. Hate to use a blade, but might be the best resort since I won't be off the machine if in motion. This is a 3-point hooked to the rear of a small tractor.
/ weed eater/chopper string #3
Piano wire? Guitar strings?
Even for small cable, use a welder to fuse the ends.
Won't fray so bad this way.
Got pictures of your setup. We wanna see it.
Pooh Bear
/ weed eater/chopper string #4
Pooh Bear
/ weed eater/chopper string #5
Heavy Square will work the best, will outlast any metal flex line. If that dont get it it is to steel blades.
/ weed eater/chopper string #6
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Peterbilt 320 EZ Pack 40yd Front Loader Garbage Truck (A59230)
2018 Peterbilt 320...
2020 Vermeer Vac-Tron LP873SDT T/A Vacuum Trailer (A59228)
2020 Vermeer...
Yamaha 4 Seat Gas Cart (A59231)
Yamaha 4 Seat Gas...
2017 FORD F-150XL CREW CAB TRUCK (A59823)
2017 FORD F-150XL...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
