Wasting Fuel or saving the engine?
/ Wasting Fuel or saving the engine? #1
Tkekic
Canfield, Ohio
Massey Ferguson 1648 with a Massey DL130 Loader, Massey 1455v, NH 477 Haybine, NH 268 Hayliner, Pequea Rotary Rake 1140, Pequea Turbo Tedder TT2000, Dixie Cjopper Classic zero turn, Kubota RTV900XT, Woods BB72x 3pt rotary mower, Woods B96 mower
Kubota M7060. Been really cold here in NE Ohio. The 7060 has a manure spreader on it for the winter. In the summer I empty the manure on a pile out in our pasture. Engine reaches operating temp. in a short time. In the winter I change the job. Question is, am I wasting fuel by keeping the engine running until it reaches normal operating temp? I do this by running it at 1500rpm but in the summer I use 6th gear low range. Now in the cold I still run it at 1500rpm but in 3rd or 4th gear. I take the long route to be sure the engine reaches normal operating temp. Am I wasting fuel? Or is a good idea to bring the engine up to temp before parking it?
/ Wasting Fuel or saving the engine? #2
IMO, it's a good idea. I even let the tractor idle longer in the winter even though the Auto OEMs will tell you it's better to start and get moving as fast as possible.. Which is only really because allows the cat/dpf/scr to get up to temp faster, not because it's actually better for the engine itself.
/ Wasting Fuel or saving the engine? #3
My tractor doesn't even reach "normal" operating temperatures after blowing snow for a half hour at 20°. I would not worry about it, unless you are somewhere that ambient temps are typically well below 0°F.
/ Wasting Fuel or saving the engine? #4
I am not sure I understand... you want to reach temp before parking it once your task is completed ? if that's the case is so no there is no used for that.
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A61307)
Bulk Lot of NEW...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2018 DRAGON 150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A61307)
FRESHLY...
2017 ADDCO ROAD SIGN DH100-ALS (A60736)
2017 ADDCO ROAD...
Ford 8210 (A60462)
Ford 8210 (A60462)
