Oil & Fuel Warming up Diesels with minimum fuel usage in mind
   / Warming up Diesels with minimum fuel usage in mind #1
candersen10
Phoenixville, PA
Cat 262c, NH TN75, JD 6430 premium, JD 5325, Kubota BX2200, Ford 1710HC, JD 333E, JD3720, Farmall 504, Farmall 404.
I have a JD CT332, a JD 5325, a JD 3720, a TN75, a Kubota GL4630, a Kubota BX2200, and a Ford 1710HC. Any thoughts on warming up these machines in light of current fuel prices? I have been told that the turbocharged engines should be warmed up for longer as well as equipment with hydrostatic transmission. I generally warm up any piece of equipment for about 5 minutes if the temperature is below 40 degrees. Should I be spending less time? What would be the negative effects of running some of my equipment when it is not fully warmed up?
   / Warming up Diesels with minimum fuel usage in mind #2
If this helps any, I ck my oil and water levels, fire the tractor up, get off, bump the tires, ck underneath for any leaks, ck the attachments and make sure every things secure and then mount up and go. By then, the temp gauge is beginning to move
   / Warming up Diesels with minimum fuel usage in mind #3
At 50F+, I just turn the key and when the glow light goes out I crank. Then back out and drive to where I am going and do what needs to be done.
Under 50F, I do the same -> but may temper it if there are sounds of complaint from the cold fluid.
Under 10F, I let it idle until the warmed up some, then drive and do. As it gets colder the idle time is longer. Also the minimum operation time is longer too. You HAVE to run a diesel for a hard hour to burn out the water and fuel that may have gotten into the oil. For that reason, I minimize winter operations.
   / Warming up Diesels with minimum fuel usage in mind #4
Long periods idling to warm up the engine is not usually the best technique. Once the engine is started and running pretty smooth (considering cold weather) go ahead and drive it, just don't work it hard till thoroughly warm. With a hydrostat in cold weather it is good to warm it up before working it hard.
This is not unlike the best practice with a car which is to avoid long warm up periods just sitting at idle. Start off slowly and gently letting it warm up before asking it to accelerate hard or go fast.
In general it is not good practice to start an ICE and shut it down before it warms up enough to "dry out" all the moisture formed when the engine first starts up from sitting cold. Diesels with considerable sulfur in the fuel are especially needy in this respect to avoid the sulfur compounds and the condensation getting together forming acids like sulfurous and sulfuric which do not promote engine health. Getting a diesel up to full operating temp and keeping it there long enough to drive off the initial condensation is good operating practice.
Pat
   / Warming up Diesels with minimum fuel usage in mind #5
Along the lines of what Pat says (and mind you, I live in California where really cold doesn't hardly ever find light of day) I think it is safe to let the tractor move slowly as it warms up. Why not use that energy to get from point A to point B? You need to get there anyway.
If the tractor is right on top of the place where it needs to work, then I would wait for it to warm up. But there are probably other low-impact things you with it while temperatures are coming up.
With autos there are a lot of folks who turn on the engine and then feel free to slam the pedal. I'm kind of a middle-of-the-road guy. I don't leave it idle for 15 minutes before going anywhere. I start going and touch the pedal very gently for several minutes while it eases into the day.
Same concept as what I do on the farm.
If I lived north I'm pretty sure that I'd use block warmer devices one way or another. But even there, I do know that oil quality has improved dramatically since when I was a kid. I seem to recall that there are even devices you can buy to pre-circulate the oil before it it started, if you want.
On another thread there was very interesting talk about when an engine should be turned off. Meaning, when does it make sense to turn off an engine such that you are saving more fuel compared to the wear that happens with each engine-start procedure. One guy posted an amazing metric saying something like you should turn off the machine if it is idle any more than 14 seconds (look at the hybrid cars as an example about how frequently the engine is shut down, like every stop). So this is another thing you can do to cut down on fuel use.
There are plenty of ways to find fuel saving behaviors. Behaviors we put out of mind when fuels seem to be affordable. And much talk here about those opportunities.
   / Warming up Diesels with minimum fuel usage in mind #6
I don't put the tractor under any load until the temp gage has gone into the green (about 3-5 minutes). This might be a bit longer in the colder weather.
However, under load means (to me) running the engine at PTO speed (about 2600 RPM on my 790). Moving the machine or other lighter duty can be done immediately after a minute or two. That is, warm up doesn't mean stationary.
So, if you are plowing or mowing a field, you could drive to the field or any other work area during warm up.
   / Warming up Diesels with minimum fuel usage in mind #7
Another thing to consider when discussing the best way, and why it is done certain ways (such as the hybrid cycle time mentioned) is who is recommending what, and what are their gains in the matter? If shutting down a vehicle is recommended after 14 seconds, and it improves the fuel milage that everyone is "looking at", who cares if it takes out some mechanical part that costs more than the fuel savings for the year?
I am not suggesting anything about hybrids or shut down times, just thought we ought to know who is suggesting what, and what do they have to gain by their suggestions?
David from jax
I run my turbo charged 2555 for a few extra minutes at idle to cool down the oil going to the tubo. As far as warming it up, I never let it sit at idle, just go to work, but I never work it hard till it is warm, if at all.
David from jax
   / Warming up Diesels with minimum fuel usage in mind #8
diesels don't warm up idling. They certainly get the oil moving, but diesels lose heat idling. You can idle your tractor all winter long, it won't get to operating temperature. It needs a load. certainly you should put that load on it gently at first as it's cold out and then start moving harder at more RPM as it warms up.
Getting the oil circulating, etc is a 15/30 second job, everywhere has oil by 30 seconds in.
However as someone mentioned above, you should always let a diesel (esp a turbo) idle down after you finish. The oil loses heat and keeps the bearings cool as it circulates and the motor cools down. I typically let it idle as it fill it with fuel at the end of the day, by then good to go.
Heat kills many more motors (diesel & gas) than cold.
   / Warming up Diesels with minimum fuel usage in mind #9
I fire up my tractor and almost immediately, set it at about 1500 rpm (have to when cold), raise the 3ph and FEL, drive out. I'm almost always going downhill; so, it stays at 1500 rpm down a little path or over to my mulch pile on the other side of the yard. By the time I get over to the mulch pile or starting down the hill, I rev it up to full PTO speed. NEVER let it just sit and idle.
Do the same for all my vehicles. Start, pull out of garage and treat them gently for a while. It's about 2 miles to the main road here, but I've been doing this all my life. NEVER just let an engine sit and idle to warm up. Even starting my old diesel at -22 F did I do this (but it had been prewarmed by a heater in the heater hose). Have NEVER had an engine failure.
Main thing with HST is to always use the lower vis fluid. Think you'd only use the higher vis stuff if you lived way south.
Ralph
   / Warming up Diesels with minimum fuel usage in mind #10
I would suggest you make a cover for the radiator out of say cloth backed Vinyl and use it to stop the air circulating through the radiator . This will warm the coolant quickly , mechanical versions of these are called "shutterstats" . Use the tractor as soon as you can but keep in mind the oils are going to be thick and flow slowly and can damage filters etc .
   / Warming up Diesels with minimum fuel usage in mind #11
I usually let mine idle until the temp gage needle starts to move (lifts off the pin stop). That ensures everything internally is well lubricated, and allows me enough time to make one last walk around before putting the machine to work.
Joe
   / Warming up Diesels with minimum fuel usage in mind #12
There are pre and post luber accessories that use a pump to circulate the engine oil before starting to avoid dry starts and after shut down to let the turbo bearings cool and not fry the oil in contact with them.
Cummins literature recommends that if you go for lengthy periods between engine runs that you install a switch to disable the fuel control solenoid. This allows you to crank the engine till you see oil pressure building and then allow it to have fuel and start. This prevents dry starts, a major contribution to engine wear. (If you hide the switch it make unauthorized use of the vehicle rather difficult.)
While pre and or post lubers can serve a useful purpose, neither will substitute for warm up. As soon as the engine is running smoothly, go ahead and drive the tractor, gently, really gently if it is hydrostat and it is really cold. After you can confirm definite positive movement of the temp gauge you should be ready for light to medium tasks and HD work when more near normal operating temps.
Turbo or not, I don't personally recommend shutting down an engine immediately after working it hard. Give it a moment to cool a bit. I like to let my Cumins B5.9 cool down to an exhaust pyro (downstream of the turbo) reading of 350 degrees which can take a while on a really hot day. A post luber like I had on my '84 Ford diesel does the waiting for you. You shut the engine off but the pump circulates the oil for a user adjustable period to cool the turbo bearings.
Hybrids were mentioned as an example of starting and stopping an engine a lot. Our '04 Prius hybrid doesn't just turn the ICE off at each stop but every time you coast more than about a second. Even on cruise if you go down a hill it may shut the ICE off until speed drops as you start back uphill again. But the engine was designed for this service. It has computer controlled valve timing and clever programing.
The starting sequence is: valves open to eliminate compression, spark and fuel off, spin the engine up to speed with a BIG electric motor (which brings up the oil pressure and lubes everything) Then set valves to normal and turn on the gas and spark. The engine is running instantly. The ICE in the Prius is shut down and restarted hundreds of times in just a little in-town driving. It is designed to do this and is not sacrificing longevity to pump up mileage figures. We have 100,000 mile warranty (including the high voltage battery.) We are at 36,000 miles in almost 48 months so anticipate lots more years before getting to 100,000. I expect to make it with no service beyond the regular schedule in the manual. So far it has been totally reliable and trouble free.
The Prius has a really good "thermos bottle" under the hood where it stores hot engine water. The water will stay really hot for a couple days (if I recall correctly.) Anyway when you "boot" the Prius a little pump takes the hot water from the thermos bottle and pumps it through the intake manifold and throttle body area to heat up the fuel delivery portions of the engine. This gets your fuel vaporizatioin "jump started" so you get good economy and low emissions right away. This essentially elliminates much of the benefit of a warm up period but not going to max throttle before the lubricants are warmed just a bit when in really cold weather is a good idea.
Pat
   / Warming up Diesels with minimum fuel usage in mind #13
Pat
Can you tap into that hot water for a morning cup of java? That would be worth while!!
jb
   / Warming up Diesels with minimum fuel usage in mind #14
jb
John, I don't usually drink coffee and coffee made with engine coolant might not be a terrific idea.
Now if you had a heat exchanger and a small reservoir of potable water... Ah a Prius with a small custom samovar!
Pat
   / Warming up Diesels with minimum fuel usage in mind #16
Use of a engine and transmission heaters would be more efficient than letting the tractor idle to warm up. Diesel engines are only about 21-22% efficient vs. at least about 33% for the electric generation cycle (if from fuel gas or oil, better if nuclear or water power). Use them even in warm weather if you think you have to get it fully warmed before using it.
Ralph
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
UNUSED RAYTREE RMLL60-60" HYD LAND LEVELER (A60432)
UNUSED RAYTREE...
2020 BOBCAT MT55 STAND-ON SKID STEER (A60429)
2020 BOBCAT MT55...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
