VERY expensive beet juice!
/ VERY expensive beet juice! #161
Might I suggest filling your tires with Elijah Craig 18 Year Old, or maybe Wild Turkey Rare Breed. That way you can look forward to the next leaky tire! And it will not freeze in the worst of winters!
Just don't try to use ether to seat the bead if you have to reseal it.You would probably burn the tire from the inside out.
Best guess estimate, it MIGHT cost well into the thousands to fill a 14.9X28 rear tire, but think of the possibilities for all those empty charred oak barrels!
Volume discount?
Aaron Z
It looks like it is likely to be WWF for me. i found a local fuel oil/lubricant seller who will charge me 120 dollars for a ~205 L drum (55 gallons). Just about 2 bucks per gallon, delivered to my farm
That's not terrible as I have to do no mixing whatsoever. I might either DIY or get my tire-guy to fill it up.
/ VERY expensive beet juice! #163
that and a drill pump, burp valve and a lil hosing, and some time on your hands and you are good to go..
soundguy
/ VERY expensive beet juice! #164
water ( free ) and rv antifreeze is what I'd do...
16.9 x 30 at 75% fill will take about 73 gallons per side... calculating water weight alone, that's about 609 pounds PER side. add in the antifreeze as ballast and the number will go up slightly.
thus at a minimum you are looking at adding about at least 1300# for just the cost of a few gallons of RV antifreeze. napa here has it at 5$ per gallon. burp adapters go for 5-9$ depending on where you get them.
soundguy
Agree!!Thats what I had them do when I purchased the tractor(water/anitfreeze) they done it for free...
/ VERY expensive beet juice! #165
soundguy
Even more convenient than a drill pump are small 110V utility pumps with hose fittings. About $20 at HF.
Even gravity works fine though.
/ VERY expensive beet juice! #166
yep.. i'm just cheap.. i like the 4$ drill pumps, and just walk away nd do other things while it is running.. :)
soundguy
I'll go shopping for a burp valve and pump. Any particular valve you guys prefer?
/ VERY expensive beet juice! #168
the burp valves are pretty generic.. tsc and napa sells them.. they usually come with a few different adapters for the tire nipples.. etc.
soundguy
/ VERY expensive beet juice! #169
Having decided to shop for a "burp valve", my first stop was at The Google:
-http://www.funeralplanning101.com/burial-interment/entombment-in-mausoleum.aspx
"Cautions
If you decide on interment in a mausoleum there are some considerations you need to be aware of. Caskets have been known to explode in a mausoleum, just as they may in a ground burial. The difference is there can be extensive damage to the mausoleum. Protective seals or liners (including those with 'burp valves') will do nothing to stop this. Whether choosing a mausoleum or sticking with a ground burial, don't bother buying a protective sealer or liner. Some mausoleums may not be as waterproof as you think and water can actually get into the caskets and cause damage."
And I thought rusted rims were the only problem:laughing:
/ VERY expensive beet juice! #170
I thought over that idea of keeping whiskey in the tires. It just won't work. Everyone knows, whiskey won't keep.
/ VERY expensive beet juice! #171
Sounds like a great idea. I'd be concerned however that contact with the tire might change the flavor just a tad. You'd need to check, probably daily, to make sure there was no such deterioration. Of course you wouldn't want the wheels to become unbalanced so it would be necessary to check both sides (daily).
Let us know how it goes.
And, I am impressed if you drank all 20 half oz sample shots at one sitting. I trust you walked or got a ride home.
The Mrs and I shared each sample, and we were with my son and his wife, so we had a designated driver. I had a double shot of the big winner when the samples were done, so I HAD to get a ride....walking was a little dicey at that point!
/ VERY expensive beet juice! #172
Blasphemy! Whiskey? Apparently you aren't from Kentucky......Whiskey is what Irishmen and Yankees drink. We're VERY specific here in the Bluegrass. It's BOURBON. True bourbon comes ONLY from a select region of Kentucky. It's the high lime content spring water, along with our specially made charred oak barrels that give bourbon it's special color, aroma, and most important....it's distinctive taste.
I'm not far from the Jim Beam distillery, closer yet to the Makers Mark distillery, and a stones throw from Wild Turkey's home. We're very close to the northern end of the Bourbon Trail. "Back in the day", Kentucky's economy was based on Bourbon whiskey, Burley tobacco, and the horse racing industry. There's a great deal of tourism built around those 3 to this day.
/ VERY expensive beet juice! #173
You forgot the most important part... By mandated law, Bourbon has to have at least 51% corn in the mash at the beginning of the fermentation process. That is the true difference between Bourbon and Whiskey. If you don't have 51% corn, you can't label the product as a Bourbon. Not to say that the items you mention above don't play a huge factor in the taste, color and aroma! :thumbsup:
Funny you mention north end of the Bourbon Trail... Family came from the south end of the trail, follow 31E south down into the Hodgenville area and that's where the old family homestead was. What say ya, neighbor?? :)
/ VERY expensive beet juice! #174
How-DEEEEE neighbor!
True Bourbon also uses a bit of the previous batch as a starter for the NEXT batch.
Coincidence or what....The Mrs and I are headed to Hodgenville next week to a reunion.
/ VERY expensive beet juice! #176
The choice is entirely up to you.
I chose Rimguard because I have a Koi pond that I work near, and if any of the above mentioned 'tire fills' were to leak into my pond, I would rather have water(which is not an option in my area), or Rimguard. Anything else is guaranteed to give me a massive fishkill.
I also chose the Rimguard because of the added weight......Can't get a lot of anything in the small tires on my Massey GC2400.
I used WWF in my old Cub Cadet for years.......sprung a leak at some point and didn't notice it right away(as I'm a truck driver and only get home on weekends).
I like the beet juice for the reasons I stated earlier:
1). Non Toxic
2) inhibits rust
3)doesn't reqiure tubes
4) tire can be plugged
5) weighs more than other 'non-toxic' ballast
I too have seen 20 year old tractors with CACI in the wheels with no problems.
I've also seen 4 year old tractors getting the rims replaced because of a couple thorns that went undetected.
Pros and Cons on both sides............just gotta choose your poison..........(so to speak).:)
/ VERY expensive beet juice! #178
i'd check out that rimguard and fish. AA local molasis plant had a spill of some desugarad material and it went into the retention pond next to them that is always populated with fream.. killed every one of em.. fast.. B.O.D. went weird just like an algea bloom had happened..
soundguy
Interesting thought.
Also, though methanol in a significant concentration would surely hurt fish, the amount of methanol in a single rear tire is not more than about 25 gallons at 30%. A 25 gallon spill of methanol near even a small "pond" of 1000 gallons would be highly diluted. As I recall soil bacteria metabolize it very quickly anyway so unclear any would get into the pond unless the tractor was parked in the pond.
/ VERY expensive beet juice! #179
yep.. most soils are gonna suck up whatever was spilt fast.. unless, like you mention, you are parked on the bank and it lets go.. etc.
soundguy
/ VERY expensive beet juice! #180
soundguy
That is always a concern to pond owners.............
Will take every bit of oxygen out of a pond in a heartbeat.
2016 Ford Taurus Sedan (A61574)
2016 Ford Taurus...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
2020 Takeuchi TL8R2 (A64126)
2020 Takeuchi...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
