Vacuum Gauge?
   / Vacuum Gauge? #1
GuglioLS
Edgewood, NM USA
Jinma 354, 1953 Ford NAA Golden Jubilee, Komatsu Bulldozer
I was wondering if anyone has ever installed or measured intake manifold vacuum on a Diesel tractor engine?
I thought it might be interesting to install a vacuum gauge on my tractor. My thinking is maybe it would indicate when the air filter is starting to clog? If I got a vacuum reading with a new filter, then as the filter aged, would there be higher vacuum when a filter is restricted? Logic makes me think so, but sometimes my logic does not make sense. Or is the needle going to bounce all over the place because of low RPM's & only 3 cylinders?
Anyway I ordered this vacuum gauge from JC Whitney to give it a try.
Should be here in a couple of days
Let me know what you think or what your predictions are.
Larry
   / Vacuum Gauge? #3
I am not to sure that will work, what you need for your task is a pressure differential gauge across the filter element..
A vacuum gauge will however tell you when you are outside of peak power range
   / Vacuum Gauge? #4
Generally speaking, diesels don't have a vacuum in the intake manifold because there's no throttle plate. :D
   / Vacuum Gauge? #5
The restriction of the air cleaner will provide for some degree of vacuum.
   / Vacuum Gauge?
SnowRidge,
That's what I am counting on, there has got to be some vacuum (pressure differential) (same difference) between the outside world and the manifold side of the filter on an engine air intake stroke. After all, that's how those fancy filterminders you posted work. Maybe not as much vacuum as I was hoping for to register on the vacuum gauge. You would think as the filter becomes more restricted, then as a cylinder is on the air intake stroke the pressure differential (vacuum) would be greater as opposed to a clean filter.
3RRL said:
Larry,
I would comment on your thread but the only vacuum I have is between my ears.:confused:
HaHaHa, ROTFLMAO
Rob,
Perhaps I should send you the gauge so you can monitor your condition. ;)
Sorry Rob, you know I admire and respect you, I just could not help myself.
All great input and discussion - thanks guys,
Larry
   / Vacuum Gauge? #8
I had a vacuum gauge monitoring a fuel filter on a diesel powered boat. It was T'eed into the fuel line between the lift pump and the filter. It saved me quite a bit of money by eliminating unnecessary filter changes.
   / Vacuum Gauge? #9
There is a vacume, which increases with an increase in filter restriction. It however is very low and is better measured in inches of water column and not inches of mercury. That gauge pictured(IN/HG) will most likley not move very far off the peg, and then only when you rev the engine, and then only due to lag as the airflow must be accelerated to meet the need. 1" of HG column is equal to roughly 14" H2O column making the water column gauge far more sensitive.
   / Vacuum Gauge? #10
Go with the FilterMinder that SnowRidge recommends. Air cleaner restriction is measured in inches of water, not inches of mercury that an automotive vacuum gauge reads. A filter is usually restricted at 25" of water, if you multiply 25 by .07355 you get 1.8" of mercury. You'll be huffing coal out your stack before you see anything registering on a mercury gauge.
Dave
Case-IH 160 Puma (A50120)
Case-IH 160 Puma...
UNUSED FUTURE EQUIPMENT SEAT (A51244)
UNUSED FUTURE...
1 T Truck Dump Bed (A50515)
1 T Truck Dump Bed...
2012 Dodge Grand Caravan Van (A50324)
2012 Dodge Grand...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
