Uses for extra Quick Hitch Top Hooks?
/ Uses for extra Quick Hitch Top Hooks? #1
Threepoint
No. VA
Kubota B2150HST w/ LA350 loader, Kubota GF1800 HST, Kioti CK3510SE HST w/ KL4030 loader, Kioti NX4510HST/cab w/ KL6010 loader
Ideas welcomed. I've ended up with four extra OEM top hooks from Harbor Freight Cat 1 quick hitches. I swapped each out with an aftermarket top hook that protrudes a bit further for easier implement engagement.
These are heavy, sturdy hooks. Hate to see them go to waste. I'm thinking some clever TBN'rs might have a suggestion on how to use them in some DIY project. :)
/ Uses for extra Quick Hitch Top Hooks? #2
Buy some material and lengthen the hooks the same as your aftermarket ones. Weld -grind-paint. List them for sale.
/ Uses for extra Quick Hitch Top Hooks? #3
Play a game of Hulk Horseshoes? :laughing:
/ Uses for extra Quick Hitch Top Hooks? #7
Put them in your big box that has other stuff to good to throw away. When the time comes that you need them you will be glad you did.
gg
/ Uses for extra Quick Hitch Top Hooks? #8
Before using them as fish hooks,, they MUST be sharpened,,,
/ Uses for extra Quick Hitch Top Hooks? #11
Would make a heck of a chain down point welded or bolted to the weight bracket or frame on the front of some tractors. Even on the rear too.
/ Uses for extra Quick Hitch Top Hooks? #13
Don't buy the horror fright QH in first place and you don't have problem of unusable items laying around....
Dale
That looks like a PITA too....4 pins to pull and line up when changing the hook position. Also 4 clips to drop on the ground and have to find in the weeds.
I modified my HF QH so I could use these receiver hitch style pins but they'd work on other QH's as well. No clips to lose.
/ Uses for extra Quick Hitch Top Hooks? #14
A hardware store magnet dropped onto the hitch solves that problem. too.
Bruce
Ha! Big Barn, if I had your talents and amazing shop, I might do this. :thumbsup: But then I'd have to compete with Quality Farm Supply, who sell them for $16.95 when they can keep 'em in stock! :laughing:
Dale
Dale, I hear ya, but at $75 or $80 each with a coupon, the HF QHs are hard to beat! My oldest is probably 16 or 17 years old, and still going strong. I use it on my NX4510HST/cab with a 750 lb Woods 7' box blade. :) I can swap out the top hooks on these things for $17, so still less than $100 all in.
Thanks, everyone, for replying. All great ideas! :thumbsup:
/ Uses for extra Quick Hitch Top Hooks? #19
LOL. Only $16.95!!! I wouldn’t be modifying them either.
Not willing to have cat food for a regular diet quite yet...
/ Uses for extra Quick Hitch Top Hooks? #20
If you have a press, they might come in handy at times.
EZ Trail 3400 (A63688)
Katolight SED60FJJ4 75kVA Towable Diesel Generator (A61572)
Katolight...
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
1660 (A59213)
1660 (A59213)
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
