Uses for extra Quick Hitch Top Hooks?
/ Uses for extra Quick Hitch Top Hooks? #1
Threepoint
No. VA
Kubota B2150HST w/ LA350 loader, Kubota GF1800 HST, Kioti CK3510SE HST w/ KL4030 loader, Kioti NX4510HST/cab w/ KL6010 loader
Ideas welcomed. I've ended up with four extra OEM top hooks from Harbor Freight Cat 1 quick hitches. I swapped each out with an aftermarket top hook that protrudes a bit further for easier implement engagement.
These are heavy, sturdy hooks. Hate to see them go to waste. I'm thinking some clever TBN'rs might have a suggestion on how to use them in some DIY project. :)
/ Uses for extra Quick Hitch Top Hooks? #2
Buy some material and lengthen the hooks the same as your aftermarket ones. Weld -grind-paint. List them for sale.
/ Uses for extra Quick Hitch Top Hooks? #3
Play a game of Hulk Horseshoes? :laughing:
/ Uses for extra Quick Hitch Top Hooks? #7
Put them in your big box that has other stuff to good to throw away. When the time comes that you need them you will be glad you did.
gg
/ Uses for extra Quick Hitch Top Hooks? #8
Before using them as fish hooks,, they MUST be sharpened,,,
/ Uses for extra Quick Hitch Top Hooks? #11
Would make a heck of a chain down point welded or bolted to the weight bracket or frame on the front of some tractors. Even on the rear too.
/ Uses for extra Quick Hitch Top Hooks? #13
Don't buy the horror fright QH in first place and you don't have problem of unusable items laying around....
Dale
That looks like a PITA too....4 pins to pull and line up when changing the hook position. Also 4 clips to drop on the ground and have to find in the weeds.
I modified my HF QH so I could use these receiver hitch style pins but they'd work on other QH's as well. No clips to lose.
/ Uses for extra Quick Hitch Top Hooks? #14
A hardware store magnet dropped onto the hitch solves that problem. too.
Bruce
Ha! Big Barn, if I had your talents and amazing shop, I might do this. :thumbsup: But then I'd have to compete with Quality Farm Supply, who sell them for $16.95 when they can keep 'em in stock! :laughing:
Dale
Dale, I hear ya, but at $75 or $80 each with a coupon, the HF QHs are hard to beat! My oldest is probably 16 or 17 years old, and still going strong. I use it on my NX4510HST/cab with a 750 lb Woods 7' box blade. :) I can swap out the top hooks on these things for $17, so still less than $100 all in.
Thanks, everyone, for replying. All great ideas! :thumbsup:
/ Uses for extra Quick Hitch Top Hooks? #19
LOL. Only $16.95!!! I wouldn’t be modifying them either.
Not willing to have cat food for a regular diet quite yet...
/ Uses for extra Quick Hitch Top Hooks? #20
If you have a press, they might come in handy at times.
2023 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59912)
2023 UTILITY VS2RA...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
John Deere 7700 (A64119)
John Deere 7700...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
John Deere 302A 50HP Front Loader Utility Tractor (A61572)
John Deere 302A...
2022 EZ-GO ELITE...
