dj1701
Veteran Member
Is anyone using a UPS (uninterrupted power supply) on their coal or pellet stove? If so, what kind and how's it working out?
Dave
Dave
Wow, I have been talking about getting one for our pellet stove. I was able to find the "starting watts" and "running watts", 425W and 70W respectively.Is anyone using a UPS (uninterrupted power supply) on their coal or pellet stove? If so, what kind and how's it working out?
Dave
I had a 600W UPS powered by a little 12 volt battery for the TV and DVR. Removed the battery and wired it to a deep cycle 12 volt RV battery.Then researching the UPS backups, a 1000W unit will allow 2 starts, or run the unit for about 8-10 minutes. Depending on the use you need it for, even the small 4-500W units will buy you some time.
I have a coal stove. When the power goes out, you have a very limited window of opportunity to get the generator going before you lose your cherry. (EMBERS)Pardon my ignorance, we use a wood burning stove not a pellet stove. Why not just let it sit for the few minutes it takes to get the generator going?
Boy that experience would have me reevaluating having a coal stove (furnace?).I have a coal stove. When the power goes out, you have a very limited window of opportunity to get the generator going before you lose your cherry. (EMBERS)
Restarting a coal stove at 2:00am on a work night is not a happy time. Anything that will add a few minutes would be helpful.
I remember running to the barn in the wee hours of the morning. Going through 2 feet of snow with just my sloggers, no socks, and my luxurious Turkish bathrobe. Time was not on my side.
have you looked into the world of solar generators? lots of options and sizes. we use one for our tv. runs the internet dish, tv, couple lights with zero interupt.Is anyone using a UPS (uninterrupted power supply) on their coal or pellet stove? If so, what kind and how's it working out?
Dave
Wood is very labor intensive. Plus you need a place to put it. We had wood, thats why I now heat with coal.Sounds like all the more reason to use wood. I can take my time as there is about a half hour from when the power goes out to when it starts making noises to get the fan running again
??? how well does it work at night or after a couple weeks of dark cloudy skies? And I'm thinking the 3 electric motors that run my pellet stove use a lot more power than a TV or any lights.have you looked into the world of solar generators? lots of options and sizes. we use one for our tv. runs the internet dish, tv, couple lights with zero interupt.
Can the UPS keep that big battery charged?I had a 600W UPS powered by a little 12 volt battery for the TV and DVR. Removed the battery and wired it to a deep cycle 12 volt RV battery.
It would power the TV for several hours.
Yep, it did. It took awhile after a long power outage.Can the UPS keep that big battery charged?
