Loader TYM TL200 Loader
/ TYM TL200 Loader #1
wandcb
Sequim, WA
Mahindra 2525
I have a 2006 TYM T400 tractor with a TL200 Loader and would like to know if this style loader has a "Float" function. Most newer models you can push the Joystick forward all the way then forward again till it clicks, putting the Loader in 'float'. Also, does anyone have a manual for the TL200 Loader or know where I can download one? Thanks.
/ TYM TL200 Loader #2
Don't have a T400 - I have a 2006 T273 w/fel with the float function, which is part of the hydro valve system. I take it yours doesn't seem to have the float. There was an issue with the valve getting sticky and not wanting to engage/disengage, so all you had to do to fix it was pull the cap off of the valve body (on my 273 it faces forward and there are two - remove the inner one closest to the frame) and grease it. Perhaps that might be what is going on with your loader.
/ TYM TL200 Loader
Thank you for the reply. After experimenting with mine I found that I 'do' have the float function. It all works fine, just didn't know it had it and hadn't tried it. Thanks again.
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2020 Chevrolet...
2018 Toyota Tacoma 4x4 Ext. Cab Pickup Truck (A66736)
2018 Toyota Tacoma...
2008 FORD CROWN VICTORIA CAR (A66091)
2008 FORD CROWN...
2018 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
953D GP Bucket (A68134)
953D GP Bucket...
2011 John Deere 6430 (A64911)
2011 John Deere...
