Loader TYM TL200 Loader
/ TYM TL200 Loader #1
wandcb
Sequim, WA
Mahindra 2525
I have a 2006 TYM T400 tractor with a TL200 Loader and would like to know if this style loader has a "Float" function. Most newer models you can push the Joystick forward all the way then forward again till it clicks, putting the Loader in 'float'. Also, does anyone have a manual for the TL200 Loader or know where I can download one? Thanks.
/ TYM TL200 Loader #2
Don't have a T400 - I have a 2006 T273 w/fel with the float function, which is part of the hydro valve system. I take it yours doesn't seem to have the float. There was an issue with the valve getting sticky and not wanting to engage/disengage, so all you had to do to fix it was pull the cap off of the valve body (on my 273 it faces forward and there are two - remove the inner one closest to the frame) and grease it. Perhaps that might be what is going on with your loader.
/ TYM TL200 Loader
Thank you for the reply. After experimenting with mine I found that I 'do' have the float function. It all works fine, just didn't know it had it and hadn't tried it. Thanks again.
2020 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2020 Toro...
Unused Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Unused Michelin...
350A Back Buddy Mobile Lifting Tool (A64194)
350A Back Buddy...
2022 EZ-GO ELITE...
2013 International DuraStar 4300 General Cable T40-C 35ft. Bucket Truck (A64194)
2013 International...
2025 32in. Tilting Bucket Mini Excavator Attachment (A64553)
2025 32in. Tilting...
