TYM 494 or Branson 4820
/ TYM 494 or Branson 4820
I have found that it really doesn’t take much pto HP to run a tiller, unless the ground is really hard. Especially not with a HST tractor that can run 540 pto speed RPMs, with really slow ground speed.
We have clay loam… it can get hard, and we will be opening some new ground. With cruise control and days and days to play with, I think I’ll be in heaven.
/ TYM 494 or Branson 4820 #82
I recommend using a plow or subsoiler to break up the clay before tilling. And clay is the worst for needing to be at the right moisture for tillage. Too dry and it’s a brick, too wet and it’s a compactable mud bog. Just right conditions till pretty well. Don’t make the mistake that I did just last year. I used an all purpose plow to break up the ground, but didn’t rototill until the next day. By then, the clods had become bricks. Don’t plow more that you can till the same day.
So the LS dealer sent me a quote for $1k less, for the tractor/tiller combo. Now... it’s not the cost that makes a big difference. It’s the fact that LS makes tractors for a brand like New Holland…
Fit and finish on the LS is very nice. The platform is well designed too. It comes with draft control, which I may or may not use. Dealer number and proximity is the same. No linked pedal on the LS.
Now, TYM has the A series diesel. Non ECM. Also, I have easy access to a “diagnostic muffler” for the 4820… which would make it essentially a pre-emission tractor if I liked.
Weight and size are similar, as well as capacities. The main difference being lift height, as the LS is 10” less.
Its so easy when you have months to make a decision, but more difficult when you are on the verge of ordering.
I will use the unit perhaps 50 hour per year. It’s a luxury. Help.
/ TYM 494 or Branson 4820 #84
$1000 is a negligible difference and so is 10” of lift. Go sit on and operate both machines. Both are good options. From my observations, the LS has the edge because of product and dealer stability. The Branson is an awesome tractor, but the TYM buyout has me wondering about how much support there will be in the future or if they will eventually just be all TYM models and support. But as many have said on this forum, local dealer support is a huge consideration. Consider local service, dealer stability and commitment. Does one dealer sell tractors from a lot behind the feed store while the other has a full service shop and parts counter?
/ TYM 494 or Branson 4820 #85
The $1000 may not be much, but 10" matters for some. The loft in my garage is too high for the LS, but well within TYM range.
LS has some fine machines, but there would be a lot of variables for me. In general, once I decide I will stick with my decision. Rushed decisions are often poor decisions.
Which LS model are they equating to the 4820?
As for the merger, I have the opposite opinion of Mr. Youtz. I think it improves both brands.
Also, which tiller are you getting? In my case, I am looking at some Rotary Cutters that push the T494/4820 specs. (Like Ironcraft 306) I like to avoid being at the edge of specs.
/ TYM 494 or Branson 4820 #86
My neighbor has an Ls xr4140 and it is a very nice tractor and he loves it.
Im comparing the LS MT347H to the 4820H. The tillers are both UM72 from Ironcraft, formerly Titan.
I think I’m more hung up on the DPF and ECM engine in the LS honestly
/ TYM 494 or Branson 4820 #88
LS has excellent fit and finish, and make a great tractor; that said, it seems that LS more electrical gremlins than other brands.
Obviously the majority of LS tractors sold are excellent machines, they wouldn't have the fanbase they have otherwise.
/ TYM 494 or Branson 4820 #89
You may be correct that TYM supports both brands 10 years into the future. I hope so for the sake of Branson owners. I’m leery after seeing what happened to my neighbor. He has a Montana tractor, which seems to be a nice machine. But he was also assured that parts would continue to be available through LS. He’s finding out that this is only true for some parts. For others, he has to search online for obscure dealer inventories and used parts. Last winter I plowed his road because his machine was down and he was searching for a water pump that he finally found after a few months.
/ TYM 494 or Branson 4820 #90
There is a significant difference. Montana was J.B. Hunt's brand and he bought tractors from various OEMs (mostly LS). Branson has always been wholly owned by Kukje until TYM bought them. The manufacturer owns the brand and makes the tractors. Montana was more like the 'store' brands that buy what they can and move on. LS has little to gain by continuing support of the Montana brand, it was not theirs. TYM has everything to gain by continuing support of Branson because it is them.
Every time I go to the LS group… it’s another tractor in limp mode, with a code. I know a lot of folks love them. I’m starting to think it really doesn’t matter what tractor you buy, as long as you have a dealer when you need one
/ TYM 494 or Branson 4820 #92
Parts availability could be a issue with a lot of brands. A lot of parts are no longer available for my Kioti Lk2554. I still can get things like filters and such but I had to modify the dash when the instrument panel was no longer available. Also had to find a different way when my sector shaft broke and was no longer available.
Manufactures will support models until it is no longer profitable to do so. Branson has some models they already have quit supporting. I chose Branson because of the mechanical injection and overall quality of the tractor. I am also aware that a time may come that I will have to be creative to keep it going. If I was buying today I still would choose a Branson for the same reasons.
/ TYM 494 or Branson 4820 #93
For the sake of a lot of owners, hopefully that’s how it plays out in ten years.
/ TYM 494 or Branson 4820 #94
I think you touched on an important thing we all miss here at times. We all have different needs and different preferences. I prefer the less complicated engine, but it is not a major driver for me. I like the color of the new Summit tractor, but I am not about to buy one. The UM72 is on my list, too. I may hold off on the tiller for now, though as I have higher priorities.
I ran some numbers on the 4820H at Big Tex. The package deal comes with 6' tiller, box blade, and mower/cutter and a PHD. $35k and change. Based on pricing I could locate for their implements (or cheapest if I didn't know make/model) the tractor portion comes out to about $28.5k. I don't know how much they charge to add the two pair of ports in the back (or 3rd function).
I also went back to my master spreadsheet... The 347H is the same one I used for comparison on LS. The FEL ht is more than a foot lower. Also, the 3pt lift is 600 lbs (20%) less. you may never need to lift more than 2700 lbs, but I figure it puts less stress on the machine when you are well within the parameters. It is also nearly 2.5 inches more narrow than the 4820. May not be much on paper, but it could be crucial if you are on a slope.
I toss this all out not to sway your opinion, but for you to use in negotiations. Any of these would be good to have and considerably more affordable than the green/Orange options.
Thanks for the rundown. I know if I travel, I can get the unit for less than I can locally, but then the shipping takes it over the top. The tractor and 6’ tiller are just under $35k here pre tax, free delivery. I’ll be adding an EA box blade and a cultipacker as well. I’ll be into it for $41k total with tax.
Going to give the LS one last look in the morning, but likely placing my 4820 order in the afternoon.
Found another tractor dealer selling the same tiller for $2700… not $3200. The TYM dealer said the best they can do is $3000, so I’ll buy it from the LS guy. Not paying $300 more when a dealer 15 miles away has the same unit. That buys a hydraulic top link
/ TYM 494 or Branson 4820 #97
In my research too I found worrisome amount of LS tractors in limb mode, and just silly things going wrong. My T474 doesn't have a seat safety switch, which I appreciate. Let me be dumb on my own terms and have a less complicated nanny machine.
/ TYM 494 or Branson 4820 #100
Mine doesn't either. I'm wondering if that nanny switch is for units that can attach a belly mower? Just curious if that's what makes the switch a requirement.
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
PALLET OF HOG CREAT PANELS (A64278)
PALLET OF HOG...
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
2014 Ford Explorer AWD SUV (A64557)
2014 Ford Explorer...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
