ty290x motor HELP!
/ ty290x motor HELP! #1
rmontague
Springfield,Missouri
NO OIL PRESSURE TO VALVE TRAIN! Installed mechanical gauge, showing 35-45 psi cold. Realised when setting valve lash (started out to replace a blown head gasket/rework injectors) NO oil on valve train while running. head gasket matched EXACTLY, can actually run a piece of wire down thru oil passage in head into block. Anyone have any ideas w/out complete teardown.
/ ty290x motor HELP! #2
Has too be a blockage somewhere. I would have guessed the gasket but you said that is not it so a tear down is going to have to take place.
Chris
/ ty290x motor HELP! #3
If you loosen the bolt that the oil is supposed to flow thru on the rocker shaft from the top of the head,do you get oil? I had heard that some of the rocker arm supports were not drilled thru for oil.
/ ty290x motor HELP! #4
Well you could remove the fitting where the oil pressure sender is located down on the block, and try and blow compressed air back from the head oil passage and see if anything blows back out that side oil port...
Thanks for the input. Had already been through most of the suggestions already. Went to full teardown on front of motor. Timing idler shaft worn almost 3/16 of an inch on bottom side. Assuming no pressure past this point, as all pressure would be lost due to incredible amount of slop inside idler gear. Will let you know when I get the new parts in and running again. Will try and post pictures soon. Gotta see it to believe it. It was bad enough it was about to jump timing. Only about .030" contact on crankshaft gear. PS, this isn't my tractor, I'm repairing it for a friend. Started out as simple head gasket job because it was pushing water out of the radiator. Looks like it had some rough service/ lack of maint. issues before he got it.
Have been working w/ another supplier, but have been reading a number of your posts, and will keep certainly keep you in mind. Thanx
/ ty290x motor HELP! #8
Let me know if we can help, we sell to most of the parts suppliers/Dealers for Jinma
Tommy
Affordable Tractor Sales
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
Kubota Diesel Engine - Pump Takeout (Skid Mounted) (A63689)
Kubota Diesel...
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
2016 TAKEUCHI TB240 EXCAVATOR (A64279)
2016 TAKEUCHI...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
