Truck mounted air compressor?
/ Truck mounted air compressor? #21
A York compressor is commonly used, as it has its own oil reservoir. I have one off of an 80's Bronco that will go in one of my trucks some day, run off a belt from the alternator with a dual pulley.
/ Truck mounted air compressor? #22
Some good suggestions so far. I have a IR T30 truck tire compressor that I have been thinking to mount on my ag service truck. The truth is that this is over kill to air up the occasional tractor tire and no real need to do a lot of mechanic work in a customers field either. I think I will check out these smaller 12 v compressors as they should be a practical solution.
/ Truck mounted air compressor? #24
I picked up a two piston air conditioner pump off a 73 Toyota celica. It is tested to 425lbs so no problem with the pressures we need. I put a propane tank for reservoir with an electric shut off. When using I have a switch in the cab with pressure gauge. It is very handy for trailer tires and such.
It has it's own crankcase so is totally independent to itself.
Duplicate
I was starting to get ready to order a compressor for the truck but was talking with my friend who was hooking an inverter up to one of his tractors for a job in their vineyard and it got me thinking about just getting a good inverter and using one of the compressors I already have.
Does anyone see a problem with mounting an inverter in the bed? If no issues is there any reason I couldn't hook it up to one of the upfitter switches on the dash? Last question, if this idea isn't completely crazy for some reason what do you guys think about inverters as I could use a crash course on them so I buy something good.
I have 2 twin tank emglo portable compressors as well as 2 pancake compressors.
/ Truck mounted air compressor? #28
I use a inverter for my airless compressor in the van... works good for inflating tires and the compressor can be used with my underlayment senco stapler.
Bought all three in 1990 and still going strong... the 2000W inverter cost a fortune back then and I still use it for my sawzall, small sidewinder skill saw, etc.
I would think mounting the inverter inside the cab would be essential... West Marine has some inverters for boats...kind of pricey last I looked... still need to be protected.
I was thinking in the bed would be ok with a cap on the bed to keep the elements out. Is there a different reason why the cab would be better?
/ Truck mounted air compressor? #30
I'd think anything mounted in my bed would eventually get damaged, unless it was in a bed mounted tool box or some other sort of protective metal enclosure. Also, you have to consider heat dissipation. Mount it in a watertight box and it might be airtight, too, and eventually cook itself. Just some things to consider. Personally, I'd mount it in the cab somewhere and either use extension cords or install an outdoor waterproof outlet to the rear of the truck somewhere protected.
What size compressor are you running off your inverter? I'm trying to find an inverter that I can possibly wire into my upfitter switch but don't know if it is a feasible idea yet. One of my switches is 30 amp.
/ Truck mounted air compressor? #32
It's a small Thomas mounted on an Emglow tank and regulator set up...
I do use it a lot.... mostly convenient to top up tires and similar... and in a pinch I have used it to staple underlayment and similar.
Had it since 1990... waited 5 year before taking the plunge and it's been worth it the last 25.
I bigger compressor would most likely overpower the inverter and it would shut down... Having the engine running also boosts the available voltage and the inverter likes that.
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2006 John Deere 990 (A64126)
2006 John Deere...
