Help me decide, 3 trucks I need to pick 1 from.
   / Help me decide, 3 trucks I need to pick 1 from. #81
But how is that much different from us seniors? I remember one of my friends spending about 5K on a Boss Mustang in 1969, on a salary of about $10K /year. This in a state where the TOP speed limit is 50 mph.
How about the seniors that buy "classic" cars and spend thousands doing hot rods (street rods, retro rods...) Of course, finding a decent engine guy is getting tougher by the day. Or, back in the day, dropping the oem for Cragars, adding a Holley double pumper?
   / Help me decide, 3 trucks I need to pick 1 from. #82
Don't buy a Ram diesel unless it's a 2025. New ZF transmission and multiple engine upgrades make it way way better. ZF trans isn't exactly "new", it's just new to the Ram. Very proven transmission.
Have no experience with the others. But if the truck will be sitting quite a bit, I would look for a Ford with 7.3 gas, or Chevy with 6.6 gas. Lot of tow companies in our area using Ford 7.3 "Godzilla" motor with good results. Modern diesels don't like sitting around.
   / Help me decide, 3 trucks I need to pick 1 from. #83
There is a 24 F250 diesel 4WD with 50k miles on CL in Foley AL that Carmax offered them $40k. Bought new camper hauler that is in good shape.
They want the same $40k for it.
Your original choices are over priced.
   / Help me decide, 3 trucks I need to pick 1 from. #84
Hogwash, bro.
Why is that? I own a 2020 Ram Cummins and it’s been excellent. If the ZF8 was so amazing, why didn’t the towing specs increase? I think its a good transmission, too. But for Ram to bring in a new transmission, and not increase towing, I know I am no longer considering a new one. I’ll wait for the 7.2L Cummins in ‘27.
   / Help me decide, 3 trucks I need to pick 1 from. #85
New?
   / Help me decide, 3 trucks I need to pick 1 from. #86
Hogwash, bro.
Your c&c truck has an Aisin 6 speed, doesn't it?
   / Help me decide, 3 trucks I need to pick 1 from. #87
I'd put money on the fact that in the first 5 years of ownership, the money you spend repairing any of the new diesels on your list will be enough to buy your current F350, and who ever buys that F350 from you will still be running it up and down the road without a care in the world. If the body is in decent shape, I'd drive what you have until you can't. Not sure if you've done any mods to it, but I put a 7 position switch in mine and run it on the lowest setting and it drives a LOT better than it did stock. I've pulled an 8500 lb camper through TN with it, and it did fine. Going up the hills, I wasn't able to run 70mph, but I was able to outpace most of the semi traffic, and that was before I put the chip in it. If you haven't replaced the high pressure oil lines in it yet, go ahead and do that. They are a common failure point. Other that, keep a CPS sensor in your glove box, and maybe get the turbo rebuilt. As far as engine durability and longevity, I'd take your 7.3 over anything made post 2007 including everything on your list. Heck, I'd rebuild that 7.3 before I wasted my money on anything newer. Now, if your body is falling apart (like mine), and the the undercarriage is getting to the point that you're starting to question how long the frame is going to be able to hold up to to that 10k trailer, that's a different story. If I was in that boat, I'd start looking for another 7.3 out in Colorado, Wyoming, or the Dakotas, but that's just me.
If I absolutely HAD to have a newer truck, I'd be looking at a gas engine over a diesel, especially if I was only going to drive it a few times per year. For almost 20 years now, new diesel trucks really only make sense when you're towing heavy loads on a regular basis. Its not that every truck has major issues. Some never have any issues, but the odds are high, and there doesn't seem to be any in-betweens. People who run diesels tend to keep the ones that aren't broken which makes the used market a lot more risky than it used to be.
If I absolutely had to choose from one of the trucks on your list, I'd go with the Ram that has 300k on the clock, and I'd choose it specifically because the PO drove it enough to put 300k on it without giving up on it. I haven't stayed up on the Cummins engine, but last I checked they were still using the same block that they used in the 6BT (5.9), and Cummins offered to warrantee that engine for 500k when dodge started putting them in the Ram. Things have obviously changed since then and the EPA has royally effed up the diesel market, but the heart of the Cummins engine is still the most robust design on the market. I once asked one of their engineers why they ran so long. He said it was because Ford and Chevy use engines designed for 3/4 and 1 ton trucks meaning where as the 6BT was designed for industrial and agricultural industry where engines are normally run at wide open throttle for the entire duration of their lives, and in some of those applications you start the engine on day 1, and only shut it off to service it. Buying a diesel truck that's only a year or two old and has around 60k on the clock BEGS the question of why the PO isn't still driving it. Think about what they paid for those trucks new, and what they likely got on trade (or are trying to sell for now) and ask yourself why a person would take that big of a loss. The most likely and logical answer is that the trucks were money pits.
Just my 2 bits,
Mark
   / Help me decide, 3 trucks I need to pick 1 from. #88
IVECO Eurocargo Tector 80 E 18 75 q​
   / Help me decide, 3 trucks I need to pick 1 from. #89
Background:I'm retired. I've been going through the process of trying to determine what truck to add to my fleet. The truck will be used in Virginia and Mississippi. It's prime purpose will be to gather dust and suck up parking space. Occasionally, maybe 5 times a year I'll drive it from Va. to Ms. towing a 10K trailer down I81, I40, I75 and getting to northeast Ms. and then after a month or three, drive back. It will carry 2 passengers, me and my wife.
I've been making this trip with about this frequency since 2011 mostly with a 2002 Ford F350 7.3, CC, dually and it's crazy I know.
But the dually is getting "long in the tooth" and I'm concerned about it breaking down.
I missed out on the deals last January and the Tariff threat kicked in and prices jacked up. But now they have come back down slightly.
Also I looked at 5L F150's and they cost almost as much.
So I've narrowed my choices down to 3 vehicles.
2023 Ram Bighorn with /edit- 6.7L
diesel < 300 miles ~53K
Warranty mostly used up sitting on the lot
2024 Ford F250 XL w/ 6.7 0 miles full warranty ~56K
2025 Ford F250 XL w/ 6.7 0 miles full warranty ~60K
To me the 2024 is the sweet spot.
/edit - what would you pick?
If your original 2002 is in good shape bodywise, you would be a fool to trade DOWN to a newer truck. The money you are going to spend on a new one would be more wisely invested in your old one with money to spare. The 7.3 is tried and true. All the new diesels are garbage!! If you do not believe me, approach an engine rebuild shop and ask them if they would even bother rebuilding ANY of these newer diesels. All garbage, especially once the warranty is gone. Better the devil you know than........
   / Help me decide, 3 trucks I need to pick 1 from. #90
... the new diesels are Not garbage, they however do have issues. At the same time, the older 6.6/5.9/7.3 are/where not perfect.
Yes, we probably all have seen 7.3L trucks that went 400k, but many didn't. We have also heard from people that had new diesels that required major repairs at 80k, but Many didn't.
With that, what the OP says, I dont see anything that mandates a new diesel; but if he wants one, any of the major brands are Likely to be fine, and provide a lifetime of good service.
Giyi Q.A Hay Spear (A57149)
Giyi Q.A Hay Spear...
Pickup Truck (A59230)
2020 Ford F-350XL (A57148)
2020 Ford F-350XL...
2006 International Business Class Roll-Off (A55272)
2006 International...
2001 Ford Explorer SUV (A56859)
2001 Ford Explorer...
Deere 35G (A53317)
Deere 35G (A53317)
