troy built carb help
/ troy built carb help #1
masseypuller
PA
Massey Harris 44,Allis B
I just bought a troy built tiller at an auction. I was told it is 1972 Horse with a 6hp tecumseh wit electric start. I have spent last few weeks getting it running but I can't find any pictures of the carb and choke. I believe there are some missing peices i think there is a rod or spring or maybe both missing the choke will not open without holding it by hand. If someone may have one of these old girls that maybe able to forward me some pictures or any info would be appreciated. Thanks Ray
/ troy built carb help #2
I am not sure but if you look at the choke lever there looks like serrated teeth on it, a "vertical" spring not attached to any thing but sits in a hole drilled in the casing and it friction holds the plate. I found a tecumseh manual somewhere on the internet that was free. Unfortunately it didn't address my problem.
My problem is I think the governer link or points advance shaft is worn and I can't get the big flywheel chipper off of the shaft to get behind the shroud to epoxy it or fix it.
there is no type of manuel choke lever it appears to be automatic possably that is why i believe there is missing rod or spring. Ray
UNUSED WOLVERINE QUICK COUPLER 2 (A64281)
UNUSED WOLVERINE...
2022 EZ-GO ELITE...
2012 Mercedes-Benz 2500 Sprinter Van (A61573)
2012 Mercedes-Benz...
New/Unused Landhonor LHR-CSC10 Squeeze Chute (A65583)
New/Unused...
1972 CHEVROLET C/60 - 18' GRAIN DUMP TRUCK (A64276)
1972 CHEVROLET...
1998 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61573)
1998 Fontaine...
