troy built carb help
/ troy built carb help #1
masseypuller
PA
Massey Harris 44,Allis B
I just bought a troy built tiller at an auction. I was told it is 1972 Horse with a 6hp tecumseh wit electric start. I have spent last few weeks getting it running but I can't find any pictures of the carb and choke. I believe there are some missing peices i think there is a rod or spring or maybe both missing the choke will not open without holding it by hand. If someone may have one of these old girls that maybe able to forward me some pictures or any info would be appreciated. Thanks Ray
/ troy built carb help #2
I am not sure but if you look at the choke lever there looks like serrated teeth on it, a "vertical" spring not attached to any thing but sits in a hole drilled in the casing and it friction holds the plate. I found a tecumseh manual somewhere on the internet that was free. Unfortunately it didn't address my problem.
My problem is I think the governer link or points advance shaft is worn and I can't get the big flywheel chipper off of the shaft to get behind the shroud to epoxy it or fix it.
there is no type of manuel choke lever it appears to be automatic possably that is why i believe there is missing rod or spring. Ray
Unused 2023 Hustler LM260 Swiftblade Tractor Loader Attachment (A66734)
Unused 2023...
DYNAPAC CA2500D PADFOOT ROLLER (A67714)
DYNAPAC CA2500D...
165 GAL WATER TANK (A68842)
165 GAL WATER TANK...
x (A68191)
x (A68191)
Unused 2023 Monroe Tufline TW92420 9ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
