Oil & Fuel Trouble Turning Off my John Deere 1050
   / Trouble Turning Off my John Deere 1050 #1
kyhunter
Lexington, KY
JD 1050 2wd with FEL
I just got done replacing the cylinder head gasket on my 1050. I had the head resurfaced. I am now having problems getting the tractor to turn off. Before working on it, I would turn the key to the off position and turn the throttle all the way down and it would stop. Now I have to mess with it for a while in order to get it to turn off. Any suggestions? Is the engine suppose to turn off when you turn the key off? This is a 3-cylinder diesel.
   / Trouble Turning Off my John Deere 1050 #2
You turn it off with the throttle.Make sure the foot throttle isn't sticking.If you have to,adjust the linkage.If you don't turn off the key,the battery will run down.
   / Trouble Turning Off my John Deere 1050 #3
I had a problem with my JD750 not shutting off. It turned out to be the foot throttle sticking, which prevents turning the throttle all the way down.
Thanks guys. I will give that a shot.
2015 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2015 Freightliner...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
2002 Freightliner FL112 S/A Day Cab Truck Tractor (A59230)
2002 Freightliner...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
