Oil & Fuel Trouble Turning Off my John Deere 1050
   / Trouble Turning Off my John Deere 1050 #1
kyhunter
Lexington, KY
JD 1050 2wd with FEL
I just got done replacing the cylinder head gasket on my 1050. I had the head resurfaced. I am now having problems getting the tractor to turn off. Before working on it, I would turn the key to the off position and turn the throttle all the way down and it would stop. Now I have to mess with it for a while in order to get it to turn off. Any suggestions? Is the engine suppose to turn off when you turn the key off? This is a 3-cylinder diesel.
   / Trouble Turning Off my John Deere 1050 #2
You turn it off with the throttle.Make sure the foot throttle isn't sticking.If you have to,adjust the linkage.If you don't turn off the key,the battery will run down.
   / Trouble Turning Off my John Deere 1050 #3
I had a problem with my JD750 not shutting off. It turned out to be the foot throttle sticking, which prevents turning the throttle all the way down.
Thanks guys. I will give that a shot.
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2016 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE S-65...
