Trick for getting the boots on your BX?
   / Trick for getting the boots on your BX? #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
Okay you folks that have replaced the boots on the front steering links... what are your tricks for getting the spring steel retaining ring on the boot? This is pissing me off.
   / Trick for getting the boots on your BX? #2
If you can catch a greased pig, then it should be easy.
Okay so much easier to remove the whole assembly. Might need a tippet wrench (22mm) to get a hold of the steering shaft. I ended up buying a cheap HD (Husky) open ended wrench and used a bench grinder to grind it down to about 3/16in thick. Boots replaced!
   / Trick for getting the boots on your BX? #9
thanks! just bookmarked this.
AIRMAN POS100S PORTABLE AIR COMPRESSOR (A52472)
AIRMAN POS100S...
Edco Hand 12" Post Hole Digger (A50774)
Edco Hand 12" Post...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
Kivel Q.A Pallet Forks (A50121)
Kivel Q.A Pallet...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
