Trick for getting the boots on your BX?
   / Trick for getting the boots on your BX? #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
Okay you folks that have replaced the boots on the front steering links... what are your tricks for getting the spring steel retaining ring on the boot? This is pissing me off.
   / Trick for getting the boots on your BX? #2
If you can catch a greased pig, then it should be easy.
Okay so much easier to remove the whole assembly. Might need a tippet wrench (22mm) to get a hold of the steering shaft. I ended up buying a cheap HD (Husky) open ended wrench and used a bench grinder to grind it down to about 3/16in thick. Boots replaced!
   / Trick for getting the boots on your BX? #9
thanks! just bookmarked this.
2025 10ft X 20ft Single Garage Metal Shed (A48081)
2025 10ft X 20ft...
2007 Jeep Wrangler Rubicon 4x4 SUV (A48082)
2007 Jeep Wrangler...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
2013 Chevrolet Caprice Sedan (A48082)
2013 Chevrolet...
2021 Delta Redirective Crash Cushion 75000 (A48081)
2021 Delta...
2013 FOREST RIVER WILDWOOD BUMPER PULL CAMPER (A50854)
2013 FOREST RIVER...
