Trick for getting the boots on your BX?
   / Trick for getting the boots on your BX? #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
Okay you folks that have replaced the boots on the front steering links... what are your tricks for getting the spring steel retaining ring on the boot? This is pissing me off.
   / Trick for getting the boots on your BX? #2
If you can catch a greased pig, then it should be easy.
Okay so much easier to remove the whole assembly. Might need a tippet wrench (22mm) to get a hold of the steering shaft. I ended up buying a cheap HD (Husky) open ended wrench and used a bench grinder to grind it down to about 3/16in thick. Boots replaced!
   / Trick for getting the boots on your BX? #9
thanks! just bookmarked this.
2015 Ford F-150 4x4 Crew Cab Pickup (A50323)
2015 Ford F-150...
2000 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
2000 HEIL TRAILER...
(5) Rolls of Barb Wire (A50515)
(5) Rolls of Barb...
48 Inch Fork Attachment (A50322)
48 Inch Fork...
2012 INTERNATIONAL WORKSTAR 7500 (A52472)
2012 INTERNATIONAL...
