Trick for getting the boots on your BX?
   / Trick for getting the boots on your BX? #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
Okay you folks that have replaced the boots on the front steering links... what are your tricks for getting the spring steel retaining ring on the boot? This is pissing me off.
   / Trick for getting the boots on your BX? #2
If you can catch a greased pig, then it should be easy.
Okay so much easier to remove the whole assembly. Might need a tippet wrench (22mm) to get a hold of the steering shaft. I ended up buying a cheap HD (Husky) open ended wrench and used a bench grinder to grind it down to about 3/16in thick. Boots replaced!
   / Trick for getting the boots on your BX? #9
thanks! just bookmarked this.
Metal Door (A50860)
Metal Door (A50860)
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
(1) Push Blade and (1) Disk (A50860)
(1) Push Blade and...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
