Trick for getting the boots on your BX?
   / Trick for getting the boots on your BX? #1
dragoneggs
Super Star Member
Seabeck, Washington
Kubota BX-25D, Kubota Z122RKW-42
Okay you folks that have replaced the boots on the front steering links... what are your tricks for getting the spring steel retaining ring on the boot? This is pissing me off.
   / Trick for getting the boots on your BX? #2
If you can catch a greased pig, then it should be easy.
Okay so much easier to remove the whole assembly. Might need a tippet wrench (22mm) to get a hold of the steering shaft. I ended up buying a cheap HD (Husky) open ended wrench and used a bench grinder to grind it down to about 3/16in thick. Boots replaced!
   / Trick for getting the boots on your BX? #9
thanks! just bookmarked this.
KJ 20'x30' Metal Garage (A50121)
KJ 20'x30' Metal...
Case IH 3408 8 Row Corn Head (A52349)
Case IH 3408 8 Row...
John Deere 7130 (A50120)
John Deere 7130...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
