Tree Puller?
/ Tree Puller? #42
Not much of a cross-section there, one guy loves it, the other hates it. Hmmm... Steve
/ Tree Puller? #43
Let us know if the brush grubber BG–10 works. I was ready to buy one until I read the reviews. I have an extreme brush grubber, the chain pull type, and it's a nice device. Only problem is, as stated earlier in this thread, it's a two man operation to work the chain. I'll buy the pallet fork model if there's a good testimonial from a TBNer.
/ Tree Puller? #44
Following-up on the above mentioned pallet fork tree puller. Anybody here have one of these? Wondering if you have to get off the tractor every time you pull a tree? (assuming it works as advertised)
/ Tree Puller? #45
Reading the PDF, it says after ripping up the the trunk and roots, to sit the plant back on the ground and the arms will lift allowing you to release the trunk.
/ Tree Puller?
Many years ago I had this on a MF240D 3 point.
View attachment 334383 View attachment 334384 View attachment 334385
It was too much of a hassle backing up to each tree, so I turned it around. any tree that I could drive over it would pull out.
I took some pictures that show all of it and the bracket for the top link, that allows it to be turned around.
/ Tree Puller? #47
Brush Grubber BG-10: I bought one of these and soon learned the gap was too big for most of the trees I wanted to remove. I'm wanting to pull out willow trees, 1-1/2 to 2 inch diameter. My co-worker suggested grinding off the welds and re-welding the plates so I can grub smaller trees. My modified tree puller is shown below -- before and after...
/ Tree Puller? #48
Well, does it work like you want?
/ Tree Puller? #49
Not sure yet. We still have snow on the ground here and I'm more of a fair-weather tree puller! Will let you know when Spring arrives. I'm hopefull this modification will do the trick.
/ Tree Puller? #51
THANKS for posting those pics!! I was actually going to order one of those today!!! Of course BrushGrubber doesn't post a "top down view" pic of the BG-10 on their web site. The stuff that I need to pull out ranges from about 3/4" - 4" with a lot of it in the same size range that your willows are in. So obviously it won't work for me. You just saved me $500 and probably a lot of headaches trying to return it.
Be sure to post pics or video of it once you put it to use. Our tractors are about the same size and we probably have the same 300CX loader. I really would like to see how that BG-10 works with the tractor.
/ Tree Puller? #52
This is a very cool tool, but I assume there is not much chance that my little Kubota L3940 with skid steer QC and third function for a grapple could begin to utilize this attachment.
What do you think?
I don't think flow is an issue but limited lift capacity of the loader seems to be the biggest limitation.
Anyone get an answer to this question. I want to know if B2650 would be able to do the same for 1 & 2 inch trees.
/ Tree Puller?
From post #17:
That is a interesting tool.
Can it be rotated for picking up logs and such?
No can't be rotated, but I did pick up some concrete with it. :D
/ Tree Puller? #56
Hey Dave, how did this work on your M7040? And what size and type trees did you pull? Thanks.
/ Tree Puller?
Pulling the Horizontal Trunk Cedar.
This is how resilient cedars are. This tree was cut with a shear about 10 years ago, but not all the way through the trunk. It fell over, but the roots from the uncut part of the trunk kept the tree alive, flat on the ground.
/ Tree Puller?
Bumping this old thread for those that haven't seen it. :)
Pulling an oddball two trunk cedar tree.
View from the seat, clamped on.
Pulled.
Shook the dirt off the roots.
Side view, note the angled trunk.
/ Tree Puller? #60
Our tree pullers have many advantages over the scissor jaw pullers.
We can custom build to fit any Machine.
We can also build dual mount units to fit on both the front and rear of the machine.
Please check us out if you are looking for a quality product made in the USA
thanks
Galen
Minnesota Implement
Minnesotaimplement.com
2020 International LT625 48" Sleeper (A62613)
2020 International...
121A (A63745)
121A (A63745)
2017 Case CX145D (A60462)
2017 Case CX145D...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
