Tree Puller?
/ Tree Puller? #61
Bumping this old thread for those that haven't seen it. :)
Pulling an oddball two trunk cedar tree.
View from the seat, clamped on.
Pulled.
Shook the dirt off the roots.
Side view, note the angled trunk.
You are making our product look good.
Thanks for posting all the pictures.
This is one of our Long Arm pullers.
We also have many other designs, and can custom build for use on any machine.
Minnesota Implement
Treeripper.com
Koeckeritz Iron and Steel
/ Tree Puller?
Yep, your product works good. :thumbsup:
It was delivered 6-13-2013 and has had a lot of use since then.
I got the Long Arm Puller so that I could see the jaws from the seat. With 4 wheel steer, I line it up, turn right and clamp on:
View from the seat of one ready to pull:
Pulled and shook the dirt off of the roots:
Side view:
Pulls roots also:
/ Tree Puller? #63
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=525148"/>
Our tree pullers have many advantages over the scissor jaw pullers.
We can custom build to fit any Machine.
We can also build dual mount units to fit on both the front and rear of the machine.
Please check us out if you are looking for a quality product made in the USA
thanks
Galen
Minnesota Implement
Minnesotaimplement.com
I have one of your tree pullers too! Recognize this one? Works great.
/ Tree Puller?
Minnesota Implement
Treeripper.com
Louie Junior, How often do you use it on the three point?
/ Tree Puller? #65
/ Tree Puller?
It is rated at 4,400 pounds, but I have a 5K crane scale that goes to overflow at 5,002, so haven't been able to measure max lift. :mad:
/ Tree Puller? #67
Only once. Although the lift capacity is greater, I found it much harder to maneuver using the 3-point hitch. Also, the loader curl function is helpful getting difficult trees out and useful shaking the dirt off the root ball.
/ Tree Puller? #68
Louie,
How much did this model cost you? I'd like to be able to use this on my 3 point hitch for a bunch of birch trees. I'm not sure how well it would work on birch because of their roots systems, but if the price is reasonable I'd give it a try.
/ Tree Puller? #70
Don't remember what I paid. Here is the link which says $1500.00. I do remember paying extra for loader and 3-point mounting. They painted it green for me which was not expected -- I am very pleased with it.
LINK
/ Tree Puller? #71
Anyone end up converting this two a three point?
I have a different version but I am think of adapting it to the three point since it have a stronger lift capacity. (Since I have a smaller tractor vs a beefy skid steer)
I just think with the lift and hydraulic top link it would be beneficial. Then with the grapple up front it would help clean up and stack.
/ Tree Puller?
I have a different version: https://www.tractorbynet.com/forums/land-clearing-equipment/354135-my-new-additions-tree-shear.html
Bumping this old Tree Puller thread to see if you converted yours to fit on the three point?
/ Tree Puller? #73
I'm not sure what others have done but I purchased a Titan 3 Point to Universal Quick Tach Adapter Skid Steer Tractor Plate & it allows me to use all of my quick attach implements on my 3PT..... I use it for my tree / post puller & my pallet forks the most.
/ Tree Puller? #74
Not sure how it would work mounted on the 3pt. Using the loader allows me to use the LandPride STP to go into the tree at an angle, push, and curl the bucket to pop the tree out. Very rarely do I just pull straight up. Not to mention that using the loader gets the implement out away from you further from branches etc. that might be in the operator area using the 3pt. If your puller has the root cutters, you can angle to sink those in and help popping roots on the bigger trees.
I guess an upside of the 3pt is that if the tree slips and comes at you, you at least have the rops over your head. This probably all depends on your loader capacity and ballast as I think my 3pt and lift are relatively comparable on the MX.
/ Tree Puller?
Pulling a multi-trunk cedar that is on the other side of the fence:
Reaching over the fence:
Clamped onto the closest trunk and raised the boom:
Raised it higher, looks like it got two trunks and one left in the ground:
Clamped onto it and pulled up:
Shook the dirt off of the roots:
/ Tree Puller? #76
Actually I never did. It痴 just sitting in the woods and I haven稚 used it in forever. I should get around to that lol.
/ Tree Puller?
KenB2920 Thanks. When you get a round tuit post the modified tree puller pictures here please.
/ Tree Puller? #78
I built a small tree spade for moving small spruce and pine up to 12' tall. I found it works well also for digging out stumps and all sorts of other tasks that the bucket is useless for. I made it out of a lawn roller and an abandoned homemade forklift I attempted years ago. I find that you sometimes need the spade on the right or left so I made it adjustable. I can simply slide it one Way or the other. Of course the loader gets strained unless it's in the middle so I only use it in the offset position only for small trees. 20200513_164106.jpeg20200510_115908.jpeg20200510_115859.jpeg
/ Tree Puller? #80
I guess I can't upload a video even a 28 second one at 22mb
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
2009 International 4300 Bucket Truck 55' (A62613)
2009 International...
12 in. WRXLS Excavator Bucket (A64194)
12 in. WRXLS...
2 Horse Trailer (A62613)
2 Horse Trailer...
