Trailer Winch Wiring
/ Trailer Winch Wiring #81
I've got bolt cutters. No torch. I bought a bunch of ring connectors so I might try my DIY vice crimp tool or my sorry soldering iron.
The more time I spend on TBN the more I realize I don't have nearly enough tools.....and I have a lot of tools....
No way a household soldering iron will touch this job. The wire and crimp size will never get hot enough to Draw the solder in.
Agreed. And this iron isn't even a decent household one.
/ Trailer Winch Wiring #83
you can also cut the cable with a 4.5 '' angle grinder with a cut off wheel attached. I'm with the torch gang. You can get a propane torch kit cheap.
Put the metal part of the connector in a vise. melt the solder (same solder used to solder copper water pipes together) into the connector. with the solder in a good hot melted state (liquid like water) , insert the wire into the connector and hold it there until it cools
I should probably just get a good soldering gun. Sears has a dual heat 400/150 watt that gets good reviews for $50. If not, I'll go with a little propane unit.
/ Trailer Winch Wiring #85
I have that one. It's great but it would not do this job to satisfaction. I would still use my torch.
Rats. So, will probably end up with a torch.
/ Trailer Winch Wiring #87
yes, I really don't believe a soldering gun is going to work on this job. you are going to have to get the fitting hotter than a solder gun can keep it.. Torch kit is best for this. Just like soldering copper pipe But easier
/ Trailer Winch Wiring #88
I use my Torch weekly. Use it to solder, light fireplace, light burn piles, melt things, thaw things, burn rope ends, ect, ect, ect.
You won't regret getting one. Spend $30 and get a auto light one that can also run Mapp Gas and you can weld with it.
/ Trailer Winch Wiring #89
weld with it ? What can you weld with map gas ? It won't get hot enough to melt silver solder. You can't gas weld with it..How /what metals are you going to weld with it ?
/ Trailer Winch Wiring #90
We have used it with aluminum boat rails and brazing rods.
Either way, a torch is a versatile tool.
/ Trailer Winch Wiring #91
never seen any aluminum brazing rods. I use used them many of times for plumbing jobs, and other small stuff.
Never been able to get the metal and rod hot enough with these small torches to braze any metal. Having said that , they are a handy tool if you don't have a big torch set
Got a torch. Got most of my terminals soldered on. Very easy. The Anderson connector terminals were made for 2 AWG wire but the power cables on the winch are 6 AWG. So, I found some copper pipe, cut a short piece, split it, rolled it into a small tube, inserted it into the the terminal, inserted the wire and soldered it in. I hope that will work okay.
I did not try to jury crimp anything, just solder. I hope that's okay. It all feels very secure and the Anderson connector instructions indicated that you could solder or crimp or both.
I still have to do the ends at the back of the truck but I'll have to run the wire first to get it the right length. I guess I'll have to do that in the driveway since I don't have a garage but I'll have to wait for warmer weather.
One question: What is up with flux? I paid $10 for what is about a tablespoon of flux. Why so pricey?
Edit: I bought Temco 2 AWG wire. Not sure if it is the very best but it is all copper, very flexible, thick insulation with a paper wrap under insulation.
/ Trailer Winch Wiring #93
... Why so pricey?
Because you needed it! :)
We've had a 2oz can of soldering flux at my employer that's been here on the workbench for 30 years and its just now getting low. It'll last you a long, long time.
/ Trailer Winch Wiring #96
Make sure you use electrical flux. I stupidly used plumbing flux on some wires and they corroded off in a couple of years. :mad:
I was told that electrical flux would do the same thing if used in excess. It was explained to me as long as the flux boils off and is replaced by the solder it should not be an issue. I have no idea if any of this is true or not. Unfortunately I did use plumbing flux which was all I could find at the time. So, if it is really a problem then the damage is done.
Edit: I only used a tiny amount of the flux and I did use resin core electrical solder so hopefully there won't be any major issues.
/ Trailer Winch Wiring #98
As long as you sealed between the two layers of copper with solder it should be fine, if you didn't it can corrode between the two layers and lose contact. I had to do a parking lot fix for a lady I used to work with when an OEM battery connector on her car that was made with 2 layers of copper corroded like that and her car wouldn't start.
Got it all done. Thanks for all the advice guys. Everything works well except for the $14 Chinese wireless remote. If the antenna wire isn't just right it doesn't work.
Amazon.com: 12V 12 Volt Wireless Remote Control Kit for Truck Jeep ATV Winch: Automotive
It works great when the antenna wire is just right. Now that I know how to wire one to the solenoid I'll probably buy a more robust one ($70....still Chinese I'm sure) and modify it to fit.
Amazon.com: Wireless Winch Remote Control: Home Improvement
Anyway, no sparks, no smoke, no shorts. So we'll see. If the truck catches fire and burns to the ground the biggest loss will be the 2 AWG wire I installed.:laughing:
Not sure. I sanded the copper so it was bright with no oxidation. It was a tight fit in the terminal (tapped it in with a hammer) and a tight fit for the wire and the whole assembly took a good bit of solder in so I think it will be okay.
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
Timberjack 608B FellaBuncher (A62679)
Timberjack 608B...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2019 KENWORTH T880 (A65643)
2019 KENWORTH T880...
INGRESOLL RAND 80 GALLON COMPRESSOR (A65643)
INGRESOLL RAND 80...
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
