Trailer Brake Controller Help.
/ Trailer Brake Controller Help. #21
On my F250 PSD I’m using a Tekonsha Prodigy Electronic Brake Control with a Tekonsha Prodigy M/N 3035 Ford Brake Control Wiring Harness. I’ve wired many vehicles for trailer brakes over the years but with the newer trucks it is basically plug and play with wiring harnesses ready to go.
From my experiences I would not want a surge brake or a timed controller for my type of interstate highways and mountain roads towing. I've used many brake controllers over the last 50+ years of pulling trailers and my setup now I find to be perfect for me no matter if I have 5,000 lbs in tow or 12,000 lbs or more.
I want complete control so that with heavy loads my trailer’s four brakes take care of trailer braking fully activated by my brake pedal through the controller. Even though I haven't experienced an out of control swaying trailer in over 20 years I want the option to reach down and activate the trailer brakes alone without my truck brakes.
I've pulled my fully loaded 12,000 lb flatbed cargo trailer over 45,000 miles in the last 3 years crossing the Sierras and Rockies on each trip from my home in CA to my home up at 8,000' in the Rockies plus I have made that same trip with my 26' Wide-Body Weekend Warrior Toy Hauler with a GVWR of 11,100 lbs and also with my fully enclosed Wells Cargo Trailer.
Trailer Brake Controllers have been a hot topic over the years at the RV.Net Forum
RV.Net Open Roads Forum: Towing
Good luck,
Jim
/ Trailer Brake Controller Help. #22
You want a nice towing experience try driving a Late Model Ford with the Integrated Trailer Brake System. I have used over 25 different brake controllers including everything from Reese and Prodigy and none hold a candle.
These controllers use fluid pressure to activate the controller. The only aftermarket one that comes close is the MaxBrake™ - Hydraulic over Electric Variable Brake Controller
I saw a test done with a dually F-350 and a big 5th wheel camper using all the other popular ones on the market and the Max Brake stopped the load in something like 20% less distance or a good 20-30'.
Chris
/ Trailer Brake Controller Help. #23
You want a nice towing experience try driving a Late Model Ford with the Integrated Trailer Brake System. [/url]
Chris
Hi Chris,
I’ve driven a new Ford F250 Diesel with the Integrated Trailer Brake System on a demo ride while pulling my Flat Bed Cargo Trailer loaded with my Bridgeport Vertical Mills, Metal Lathes, and as much of my shop equipment I could load onto my trailer This was just before I left on one of my trips when I finally moved my machine shop to my place in the Rockies.
I’ve tried pretty much everything ever sold or jury rigged since I started driving on the farm as a kid in the late 40s but I want the possibility of separate control of the trailer brakes only in case of high speed swaying or anything else that required me to control the trailer separately or even to use the trailer brakes to stop my truck if I lost my power brakes. It's been many years since I’ve had wild rides caused by improper trailer loading or tire blow-outs but those wild rides still stick in my mind!
The Integrated Trailer Brake System was impressive but for now I have what I need.
Thanks for your input,
Jim
/ Trailer Brake Controller Help. #24
A lot of the guys here have more experience with the subject than me, but don't think that a cheaper system is unsafe. I think a trailer in good shape wired up correctly even with a low priced controller that is adjusted will be more than adequate. There are those out there that believe that anything less than the very best available is an accident waiting to happen. A lot of it lies with the driver being cautious.
/ Trailer Brake Controller Help. #25
and taking the 15 seconds to adjust the controller to the individual trailer after you connect. The efectiveness of the trailer brakes vary a great deal. :eek:
Taking the time for a few test stops to get the controller dialed in is not much work. I once owned a small 26 foot fifth wheel travel trailer that was built with very large axels and brakes. It would easily lock all 4 wheels if the controller wasn't dialed in. The oversized brakes made it great for towing my boat behind it in tandem.:D:D:D:D
/ Trailer Brake Controller Help. #26
Ditto that 100%... my cheap controller controls my trailer breaks 98% as good as one nearly 3x it's price.
a good traielr with serviceale brakes and wireing is the first step.. plugging in and making some test stops as you pull out of your place is the 2nd step.
If lower end controllers were 100% useless.. they wouldn't be sold.. some people are blindly stuck on a brand name.. or a price expectation.. it's not always the case though..
soundguy
/ Trailer Brake Controller Help. #27
The one I have in my 3500 is a Brakesmart (pretty much the same thing as Maxbrake) It uses a transducer on the brake line to activate the brakes in proportion to the hydraulic pressure. It shows brake line pressure and voltage and some other things like it will spit out Bible quotes when the brakes aren't being used. That feature is turned off on mine.
Mike
Link
I'm probably going to go with the Prodigy. Its not the cheapest or the most expensive but should be just right for my needs. This trailer weighs about 2500 pounds. The horses we'll pull are no more than 1000 each. Will usually just be one but with two we're at 4500 pounds. Add a few hundred more for hay, water, tack, etc. Trailer is in good shape. Will pull no more than once a month. Terrain is anything from gentle hills to low mountain.
Will make some test runs with the trailer but not sure about how to do that with horses on board. When I test it, do I need to do hard braking?
Also, trailer has some sort of kill switch/cable. What is that?
/ Trailer Brake Controller Help. #30
For testing the brakes just get going about 15mph. Put on the trailer brakes by moving the test button on the controller to activate them. You should feel them pull down the truck. If they lock up use the adjustment to remove some power.
The "kill switch" is called a Brake-Away. Hook it to the hitch independent of the ball or chains. It should have its own clip. The law states that if the trailer becomes disconnected from the tow vehicle it should apply brakes and hold it for no less than 15 minutes. All it is really is a second path for electricity to the brakes. When pulled it removes a plunger which allows 2 spring loaded contacts to complete the circuit applying voltage from the trailers on-board battery to the brakes. This is assuming the battery is charged and all wiring is proper.
One of the relays you will be installing with your Ford Kit you mentioned you had controls voltage to the pin at the 1 o-clock (12v)pin and to the 7 o-clock (ground)pin in the 7 way plug. I am pretty sure on your age truck this should only supply power with the truck is on and running. Some supply it all the time and some only apply if the key is on so check all the possibilities.
Chris
/ Trailer Brake Controller Help. #31
George,
The Break Away Cable should be attached to your Truck's Trailer Hitch and if the trailer should break free of the truck the Break Away Cable will pull the pin activating the Trailer's Brakes if the small battery is charged. Normally the battery is charged by your truck but if the trailer has not been used in a while it might be dead. This Break Away System is required in most states and according to some Highway Patrol Friends they look to see if the Break Away Cable is attached when they pass you on the highway. Do not pull the Break Away Cable pin to test the system while the controller is attached as it can damage the controller.
Good luck,
Jim
Thanks guys. Don't recall seeing a battery on the trailer but I did not look for one either. I will do that and make sure it is charged before we tow.
Learning a lot here.
/ Trailer Brake Controller Help. #33
Leave a little slack in the break-away cable so if you are maneuvering the trailer to almost jack-knifed backing in a tight spot it won't activate the trailer brakes or possibly damage your controller.
Back in the 90's I was asked to tow a friend's loaded 3 horse trailer about 300 miles to a breeding farm and the battery was missing. I bought a new battery for less than $30. A complete new break-away kit was about $50 with a battery charger.
Don't forget to cross the Trailer Hitch Safety Chains. This gives the Trailer Tongue someplace to ride if the trailer partially brakes free. I've had it happen many years ago pulling a friends loaded tilt trailer at night in the rain just as I entered a congested highway! It was a cheap commonly used hitch that held on for five miles before releasing even though locked. The Safety Chains saved the day!!
Good luck,
Jim
/ Trailer Brake Controller Help. #34
that bat is a lil rechargeable job, and usually sets in a lil box along with a charge controller and may be about the size of a grapefruit squared off.. not a big thing by any means..
soudnguy
Here is an update of what I did:
1) Got the Tekonsha Prodigy controller along with the wiring harness for my truck. The total on that was $113. Probably more than I had to spend, but it was an easy install and it seems like a good product. Even comes with a DVD for basic installation instructions. Bought it from eTrailer.com. Those folks are on their toes. Great website. Cheap and super fast shipping.
2) For the rear end of the truck I bit the bullet and bought the OEM Ford 7 pin round wiring harness. It was ridiculously expensive at $105. However, I think it was worth every penny. First, you just remove the 4 pin flat connector harness that came with the truck and plug the new harness in. Second, the OEM 4 flat has a pigtail that splits off past the plug and goes to the taillights which would have required me to do a bit of additional wiring. The new 7 pin harness includes this pigtail so it was plug and play for real. The new OEM harness had all the little plastic pins that hold it to the frame, etc. for a perfect OEM looking install. Third, it came with the bracket that holds the plug. It bolts right to the bumper. Fourth, the plug unit has the 7 pin and a four pin connector so I will not need any adapters for the trailers I'll be using.
I already had the relay do-dads that go in the breaker box in the engine compartment.
I have not hooked up or tested with a trailer yet. Will do that this week sometime. Got a horse show on Saturday.
I probably could have spent half as much money and done just as well, but this set up was plug and play at its best and that eliminates the weakest link from the process...me. It was also quick and saved me a lot of time.
Thanks for the excellent info and advice. I always get what I need here at TBN.
/ Trailer Brake Controller Help. #36
Glad you got it all hooked up. You did right by getting the plug and play stuff. Any connection under the rear bumper area will cause issues sooner or later. It may be 10 years down the road but it will. Plus like you said your time is worth something so yes, you could have done it for $50 but would have taken 2 hours to do it properly versus 10 minutes.
I would test everything asap so there are no surprises the day you need to use the trailer.
Chris
I'm going to test it with my little 4x8 trailer, then hook it to the horse trailer empty and make sure everything works then load the horse and set the brake controller.
/ Trailer Brake Controller Help. #38
These controllers use fluid pressure to activate the controller. The only aftermarket one that comes close is the MaxBrake - Hydraulic over Electric Variable Brake Controller
Chris
The MaxBrake looks to be the best out there now that in spite of rave revues, the BrakeSmart is no more.
Still, I could not see the cost so I went with a Tekonsha P3 for my Freightshaker. Pretty "intelligent" unit and easy to set up and adjust. Picked it up for about 130 with shipping. I had some questions which Tekonsha was quick to reply to. Though my trailer has electric brakes, it is a possibility that I may have one with hydraulic/electric in the future which the P3 will work with with just the touch of a button. Way cool!
/ Trailer Brake Controller Help. #39
Trouble with the BrakeSmart seems to be it's availability - lack thereof.
I had tried for a few years to buy one, they were always on the edge of contracting a new builder/supplier.
Then they re-appeared, but only through some obscure speed shop.
If they REALLY spout religious quotations then I am completely turned off the idea, regardless of what religion it represents, whether or not that coincides with mine, etc.
I really LIKE the idea of braking force being some function of hydraulic pressure, but it DOES tie your trailer to that one vehicle.
/ Trailer Brake Controller Help. #40
What's this have to do with brake controllers? :confused:
HONDA Plate Compactor (A64553)
HONDA Plate...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
3-Pt Backhoe (A66285)
KMC 13 SHANK H.C. CHISEL PLOW, 3PT (A64278)
KMC 13 SHANK H.C...
2010 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2010 Ford F-250...
