trail clearing technique and tools
/ trail clearing technique and tools #241
Sorry for being so piano. Here is a before and after pair of shots looking SW from the first pic I posted a few days ago (sitting on the deadfall). The trail continues on down the other side of the hill and a deep 30 foot ravine is just over to the right. There is also a branch to the right that goes over to another clearing I’ll try to get to tomorrow.
The 2 wheeler is great for this work except when it isn’t. On level ground it’s easy and can be controlled with one hand walking along side, but on rutted, uneven ground it can be a beast, so on uneven/ deeply rutted ground you need to strategize what direction you approach from to avoid dropping the wheels into a hole, grounding the tractor front and rear. Usually you can simply wrestle the tractor, rocking a bit to change direction and it will plow out of most situations. The filled tires help and hurt, depending.it’s tempting to run over the saplings in 2nd gear, but better to stay in first until you know what your dealing with.
I love the 853 maintenance, starts on first pull and you really just need to make sure air filter is maintained. Leaves tend to collect on the Honda engine so you need to keep that clear (theres a screen available). The del-Morino brush mower is very robust and only needs a few squirts of grease in a single zerk fitting. One thing it needs is a shield of some sort for the wiring on the right side of the Honda engine when cutting saplings.
This location (one of numerous trails, about 2 miles total I estimate) is about a 1500 foot walk from our shed, no problem with the tractor, but a long walk carrying the pole saw (though plenty of little projects along the way). Thinking some sort of sled may be in order until a proper vehicle is obtained so gas and saws can be staged as the projects get farther from the house. Really the immediate goal is over a few weeks manage to get back to all the clearings and get as many saplings (mostly beech) that are 5 years old. Talking to a fellow with skid steers and forestry heads to come in and do a proper clean up, but he shouldn’t have all the fun. One advantage of the walk behind is you‘re close to the ground so get to know the flora and fauna really well.
/ trail clearing technique and tools #243
What is the advantage of running that string trimmer without a guard? does it not throw a lot of stuff at you?
I use one of these kunz mowers around the yard, thing is a beast if you can pull it over it it will make it dissapear. from 2" saplings to 6' cattails
Yes it does so we wear double front pants. We also wear full face forestry helmets but in general, its not that big of a problem. If you are working in gravel, that's when it gets realy exciting. My spouse knocked the glass out of a less than one year old truck doing that..
On the trails this weekend. All these branches that go over the road, need to come down or the snow will do that when we want to be grooming here. What saw should we be using?
Here the trail goes right over the Canadian Yew! Not a big deal and the land owner likes it. Its like weeds here!
Leaners being removed. That means these small trees already lean towards the road and will come down with snow.
/ trail clearing technique and tools #246
Here is a trail that I cleared today with my slightly more mechanized approach, namely a KX121 with a 4' mower head.
We spent the day clearing a trail located in the Ottawa NF about an hour south of us. Here is more info about the Deer Marsh trail. I'll post a few photos after they are processed. (yes I really do edit them :LOL: )
Up here the Spruce budworm feeds and kills the balsam fir and white spruce, and to a lesser extent on red spruce and black spruce. This keep dead-fall removal a full time job and we cleared 5 off the trail in the first 1/4 of a mile. But after we get out of the spruce area, then its more like hiking.
This 3 mile trail is not atv accessible so we hike and carry all tools around with us. I hope you can see why we bring a pole saw, axe and loppers for clearing it.
The tool backpack. This Dakine Builder Pack is made for trail working.
/ trail clearing technique and tools #251
I'm clearing about a 1/4 mile trail on my north side of the property. I cleared a 3/4 mile trail on the back side two years ago. Since I can't fit my tractor with rotary cutter on the north side I drive my side by side with large pruning shears and two chain saws down the path I want to make. The hard part is getting a tree stump low enough with the chain saw without hitting dirt. I then cut a deep groove in the shape of a cross on the top of the stump to help deterioration over the years.
Can't remember the last time I used a pole saw.
I'm clearing about a 1/4 mile trail on my north side of the property. I cleared a 3/4 mile trail on the back side two years ago. Since I can't fit my tractor with rotary cutter on the north side I drive my side by side with large pruning shears and two chain saws down the path I want to make. The hard part is getting a tree stump low enough with the chain saw without hitting dirt. I then cut a deep groove in the shape of a cross on the top of the stump to help deterioration over the years. Can't remember the last time I used a pole saw.
Within the walking zone, we cut stumps near or at, dirt level. Trail clearing is tough on chains, that's the nature of the beast. We go into the field with extra chains and files.
I believe I used my ms261 saw once this summer. We are in the northern hardwood forest with a mix of boreal which is mostly south of us. I'd surmise our forest is different than Texas. :LOL:
/ trail clearing technique and tools #253
Well cleared some fence line today, went over the area with a skidsteer mower and a pull behind rough cutter earlier in the year and now just cleaning right against the wire and whatever didn't get mulched by the mowers.
We are heading back out to clear more XC tail over the weekend in some fabulous fall weather. I'm also building a mini trail head kiosk if anyone cares. I'll post pics of it later. Its just 3x3ft made from 3/4 plywood and has a roof over it.
Bridge maintenance today and below is the bridge. General trail clearing pics to follow.
The same bridge seen today. And why do we use pole saws?
More clearing pics from Sunday. We are now "officially" done clearing it. :p
This "dog leg" tree is a common sight here. Does anyone know why this happens here so often?
You can see the blue tape we put up to mark our way.
Where the blue bar is poked in, is about where the kiosk will get planted. I'm still working on it.
Does something (like a tree/branch/log) fall on the tree when it's small, pushing it over, and it curves back upright as it grows?
Well something does fall on trees here. :LOL: Its snow, and it breaks many shoots off. But some survive and grow with this dog leg in them.
