Tubes Tractor Valve stem question.
/ Tractor Valve stem question. #1
DB Pilot
SW, New York
Case Farmall 65A, L3800 Kubota, BX2200 Kubota
I am in the process of changing one of my David Brown 780 rear tires. Today I put the inner rim and the inner tube on the Wheel rim. :) Then got stopped. :confused: Looking at the inner tubes valve stem there is a 1" washer and then the rim nut. Question is does the washer stay next to the inner tube inside the wheel rim or does it go outside of the wheel rim with the rim nut. :eek:
Got to be sure on this one as when that outer tire rim gets put on the rim it will be a lot of work to change things around. :thumbdown:
Alright, No body Knows. :confused3: Surprisingly the dealer I bought the tire from was watching his emails today and I got a really fast reply. Turns out as I expected the washer stays next to the innertube on the inside of the wheel rim. Had to be sure as once the outer tire rim gets put on that washer is going to be there awhile, knock on wood. :laughing:
/ Tractor Valve stem question. #3
Interesting - I just saw your post. The rear tires on my Kubota (16.9 - 28) have a washer on both inside and outside. Anyhow, glad you found out for certain. The weight of a rear is nothing to fool with.
LOADER MOUNT HAY SPEAR (A63291)
LOADER MOUNT HAY...
RAIN FLOW 1 PANEL SLEAD BEDDER BED PRESS (A63291)
RAIN FLOW 1 PANEL...
2019 Ford Explorer AWD SUV (A61574)
2019 Ford Explorer...
2004 Talbert Lowboy Detach Trailer (A64047)
2004 Talbert...
2016 Yanmar Vio 45 Mini Excavator (A64047)
2016 Yanmar Vio 45...
2020 FORD RANGER(INOPERABLE) (A63569)
2020 FORD...
