Fuddyduddy1952
Super Member
- Joined
- Aug 10, 2022
- Messages
- 9,879
- Tractor
- john deere
Antifreeze in Grandad's tractor I have for 49 years!The antifreeze has been in the tires of the Yanmar for 22 years, still no problems.
"Antifreeze. Antifreeze (ethylene glycol) in a 50/50 mix with water is freeze resistant to minus 34 F and weighs 9.4 pounds per gallon."Antifreeze is approximate 8.5 ,it is mostly water which is 8.34 pounds per gallon
Bingo! I don't know where YanmarFever lives, but the fact that his profile & signature mention watermelons I'd guess it's somewhere that doesn't get very cold.I guess it would really depend on my location. Beet juice if I was up north. Water with washer fluid will work down here.
It's also highly toxic. Not something you'd want pets/livestock near if it leaks or spills. Bet it's not too good for the soil either."Antifreeze. Antifreeze (ethylene glycol) in a 50/50 mix with water is freeze resistant to minus 34 F and weighs 9.4 pounds per gallon."
I have thought about buying some sugar in bulk and making a syrup solution of 2 parts sugar and one part water by using hot water. I know this will remain liquid at room temperature but I don't know what the freezing temperature is. I also don't know where to buy the cheapest sugar and if it would be cheap enough, cheaper than non-toxic anti-freeze is where I live. Since I live on an island I will need to add liquid myself or else transport my tires a long way to get them filled. My local Les Schwab will fill my tires with their liquid, but it weighs almost exactly the same as water and costs more than 4 bucks per gallon. There must be some place that sells cheap sugar in 100 pound sacks in the Puget Sound region. Then I can maybe plan a sightseeing trip and pick up a couple sacks. When I get new tires I can then fill them too.
Eric
Wow, I never considered this. I suppose some rodents might be able to smell the sugar through the rubber.I think sugar in tires will attract a universe of gnawing animals during winter, when natural food is short. Your tires and your tractor wiring will be at risk.
It is until you spring a leak. Just put wheel weights on and do it right the first time.Bingo! I don't know where YanmarFever lives, but the fact that his profile & signature mention watermelons I'd guess it's somewhere that doesn't get very cold.
I always thought Rimguard was gold standard for liquid ballast.
Even at that price, it can run into some big dollars, and the few issues that come along with liquid ballast. My used tractor came with wheel weights, 3 - 50# per side. Works well enough for my needs.Rv antifreeze is on sale for 2.99 at Runnings right now and it’s non toxic.
I bet I could put some water in it aswell. I don’t need -50 degrees. It dosent get cold in Connecticut anymore haha. I’m thinking maybe I’ll do those 75 weights I found on fb and some antifreeze. I max out the loader pretty regularly moving my firewood. I could have used the next size tractor but that woulda priced me out of a backhoe.Even at that price, it can run into some big dollars, and the few issues that come along with liquid ballast. My used tractor came with wheel weights, 3 - 50# per side. Works well enough for my needs.
I've only done the RV/Marine pink stuff at $1.69/gallon pre-covid era.I’m changing out my tires and my rears have rim guard in them. I pulled out the valve core and I got maybe 6-7 gallons out extremely slowly. I ended up taking the wheel off the tractor and laying it flat on the forks and putting a ratchet strap around it to squeeze it to drain the juice faster. It was miserably slow and there’s still a few gallons in there I bet. It got dark outside so I had to put it back in the tractor and put it away. I haven’t even touched the other side yet.
I have no desire to reuse the rim guard. I’ll use washer fluid or antifreeze. Rim guard is a pita if you have any tire issues it gets everywhere. It also gums up your air chucks if you get any inside.
Any suggestions on how to speed this up? Thanks, mike
I don't know about that. I grew up around 45.2 degrees N. latitude. We grew watermelons up there and temps usually get down to -30 F (or worse) every winter.& signature mention watermelons I'd guess it's somewhere that doesn't get very cold.
He's just south of me in a land of Dixie.Bingo! I don't know where YanmarFever lives, but the fact that his profile & signature mention watermelons I'd guess it's somewhere that doesn't get very cold.
Again..."Antifreeze in Grandad's tractor I have for 49 years!" No leak(s).Bingo! I don't know where YanmarFever lives, but the fact that his profile & signature mention watermelons I'd guess it's somewhere that doesn't get very cold.
Not something I'd lose sleep over. Go ahead...your turn.
Boy, you are blessed for 49 years. While I don't run it, and never will, of all the people around here that do run some liquid balast, all of them have either had leaks, or corrosion of rims with seepage.Again..."Antifreeze in Grandad's tractor I have for 49 years!" No leak(s).
I don't have livestock and pets around my tractor tires anyway. Besides, I bet most people have antifreeze in their cars and trucks that ARE around pets. Lots more places for antifreeze to leak out of than a tractor tire.Not something I'd lose sleep over. Go ahead...your turn.
The only problems I see with regular antifreeze is if it might damage the rubber and slow leaks. I have had tractor tires with slow leaks and I address those leaks quickly, not because of any type of toxic release but because I don't want flat tires on my equipment. But I'm pretty sure that antifreeze from cooling systems is a much larger contributor to toxic antifreeze releases than leaky tires.Again..."Antifreeze in Grandad's tractor I have for 49 years!" No leak(s).
Leaks from corrosion with liquid ballast are undoubtedly from calcium chloride, not other fills. My dealer uses a new product called bio ballast. My tractor was delivered with this product. Read about it.Boy, you are blessed for 49 years. While I don't run it, and never will, of all the people around here that do run some liquid balast, all of them have either had leaks, or corrosion of rims with seepage.
Yes, there are cars, trucks, tractors that can and will leak antifreeze, it's more common for tires to leak.
Yes, calcium chloride. We had corrosion and leaks from that, but not antifreeze. Antifreeze used in vehicles, even the tractors OWN cooling system, runs through rubber hoses constantly. If anyone is concerned about toxicity then I'd use it in everything, tires and cooling systems.Leaks from corrosion with liquid ballast are undoubtedly from calcium chloride, not other fills. My dealer uses a new product called bio ballast. My tractor was delivered with this product. Read about it.
Tire Ballast - EnviroTech Services
envirotechservices.com
